Ashlar Pattern Help
/ Ashlar Pattern Help #1
garren
Fort Worth,TX
Kubota L2800 with HST/R4 Tires
Last year I decided to fix a broken patio where the slab had cracked in half. I used the backhoe to dig down at the corners, did a little jacking and added some concrete piers. This year I wanted to cap it with some slate that was given to me. My neighbor, who is a landscaper, was asked by a homeowner to haul off the leftover stone that a pool company had left behind. He didn't feel like unloading it so he gave it to me. I used the forks and tractor to palletize and store it. It's basically about 2 pallets worth.
What I found was that I have three shapes...small squares, rectangles and the rest are large random broken pieces. I had assumed these were used to make an Ashlar pattern around a pool deck and I would do the same on my patio. I googled the Ashlar layout and what I see in the pictures is that the small squares should be the same width as the rectangles. Mine aren't. My squares are 7.75" X 7.75" and the rectangles are 6" X 12". I know with all the members here some of you have experience laying stone. What layout do I use with these size pieces? Am I looking at these google images wrong?
I'm guessing a large square could be cut from the broken pieces but I'm stuck on what to do about the width of the small squares not matching the rectangles. :confused:
Heres a couple of links to images that I had looked at. This first link actually looks like the stone I have.
Halona Stone Mats, Halona Stone Flooring from Realstone Systems
Granite Works - Ashlar Patterns
/ Ashlar Pattern Help #2
If you need the smaller stones just rent a stone saw, or diamond blade and cut them.
We did layouts like this, when I was doing landscaping, we would put most of the big ones down and then lay in the medium and then the small.
what you could do is paint a square on the ground and mess around with different fits. find one you like.
Ok...I've tried the square on the ground and cant get any of the existing pieces to work out...looks like I'm gonna have to cut them. :(
/ Ashlar Pattern Help #4
Do you have to cut them all or can you get away with only cutting a few to fill in the holes?
2025 24in Bucket Mini Excavator Attachment (A66734)
2025 24in Bucket...
CM TRAILER  10 FOOT ENCLOSED TRAILER (A67714)
CM TRAILER 10...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2017 PETERBILT 579 (A67714)
2017 PETERBILT 579...
2006 PETERBILT 379 (INOPERABLE0 (A67714)
2006 PETERBILT 379...
