Feedback on JCB MIDI and M59
/ Feedback on JCB MIDI and M59 #21
Mark,
Sounds like a plan to me, the M59 should be a great machine. Back in 2005 I paid $7600 for the Laurin cab and added the Hammond ac kit to it for another 1900. So about $9500 total, this should help you get an idea of what to pay today.
Having a 4520 cab and the 110 Laurin cab I think from a utiltarian standpoint the Laurin has more room and is every bit as good where it matters. I can also say that having a cabbed tlb is a great way to go.
/ Feedback on JCB MIDI and M59 #22
Either way I think your happy M59 is a really good machine. I'm looking for a compact TLB right now but I'm pretty well limited to a 110 because of my budget or I'd be looking for an M59
Thanks but remember the primary goal was to save the use of my 6 bobcat attachments so I need the flow - the smaller tractors just don't have the flow necessary to keep it moving at the front end - like 17 gal per minute which gets me to a jd5083 or a Kubota 8540 which is larger than i'd like- thats how i got to the m59 in the first place
/ Feedback on JCB MIDI and M59 #24
Oh, that makes sense then. The M59 sure is a beast. Be sure to keep us posted along the way and post some pics when she arrives!:thumbsup:
/ Feedback on JCB MIDI and M59 #25
Jenkinsph
I am looking at getting a used M59 that has the Laurin cab on it with heat but no A/C at this point and have been trying to figure out how to add the A/C. The dealer claims that they have to change the roof to install the Laurin A/C and want $4,000 to add it. The price you indicated for the Hammond unit is much better. Did you purchase it separately and add it yourself?
Lauren
/ Feedback on JCB MIDI and M59 #26
Jenkinsph
I went to the Hammond website which doesn't have a lot of information. However they show the price of their JD110 kit as being almost $3,300. Did you buy factory direct or at a discount through a reseller?
Lauren
/ Feedback on JCB MIDI and M59 #27
I bought the kit directly from Hammond in 2006 IIRC. I am in the hvac business too, so that helped with the cost and saved a few hundred, sounds like the cost for everything is going up alot though.
If I lived in Canada I would consider skipping the ac to see if I could get by without it for the prices I am hearing today. In Arizona and New Mexico which were my intended places to use it the ac was a must have.
/ Feedback on JCB MIDI and M59 #28
Thanks Jenkinsph
Unfortunately I live in the Toronto area and it can get quite warm here in the summer - especially once all the hydraulic oil gets warmed up after a couple of hours on the backhoe. I may not get the A/C this year just to try it out but it is definitely a long term goal - assuming I am able to make a deal on this machine. I think the dealer is still $5,000 - $6,000 too high as I see used M59's with similar or less hours with asking prices $10,000 - $14,000 less. If the dealer is inflexible, I will find another M59 and put the Laurin cab on with A/C from the start.
It looks like adding A/C would mean ripping out the existing heat as it is a roof top unit too. I assumed the heat only would be low in the cab but it is not.
Lauren
/ Feedback on JCB MIDI and M59 #29
With mine the evaporater coil is added to the heater coil which is kept in place. Not sure what Laurin is using for the newer cabs.
/ Feedback on JCB MIDI and M59 #30
If I go ahead with this M59 I'll contact Laurin directly and see what my options are for adding A/C.
/ Feedback on JCB MIDI and M59 #31
Kubota (M-59) | Laurin inc | Cabines, canopes et compacteurs pour tracteur et camion
If you click on the "Download this flyer" in the upper right hand corner it says "Optional eclipse roof, required with air conditioning"
I do think if you found a different A/C supplier you could keep the original roof though.
Does the dealer your looking at the M59 at have it listed on the internet, just so we can take a look?:thumbsup:
/ Feedback on JCB MIDI and M59 #32
MartianTractorMan
The machine I am looking at is not on the internet. I have just looked at the Laurin brochure (Laurin inc | Cabines, canopes et compacteurs pour tracteur et camion) for the M59 and the machine I looked at has the EX version of the Eclipse cab based on the photo of the inside roof and description on page two of the brochure. The same set of pictures shows an optional A/C unit mounted on the rear portion of the roof and the inside roof shot shows the cooling ducts which do not exist on the machine I looked at.
This is not a major concern at this point - I will take the machine the way it is if the dealer and I can come to an arrangement. I know it has been sitting on their lot for at least eight months now and they did recently drop the asking price by $5,000 but I think they are still at least that much too high so we'll see what happens.
Lauren
2025 Swict 78in. Bucket Skid Steer Attachment (A61572)
2025 Swict 78in...
KMC 6-36 (A64119)
KMC 6-36 (A64119)
speed limit sign (A61572)
speed limit sign...
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
Adams Weight Hopper (A63688)
Adams Weight...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A63688)
2021 Unverferth...
