JD 955 Compact replace hydraulic pump
/ JD 955 Compact replace hydraulic pump #1
Hoopcoachd
JD 955 Compact Tractor
While using my JD 955 Compact to bush hog today I lost all power - steering, transmission, bucket, PTO. Assume it is a faulty hydraulic pump. Tractor is a 1995 with just over 800 hours - maybe...bought it less than 6 months ago and it has run fine until now. Fluid is topped off and checked every week. Any thoughts on how to replace the pump unit and how much will it cost. Never owned a tractor but have pulled engines from my other vehicles...have tools and time.
/ JD 955 Compact replace hydraulic pump #2
Just replaced the pump on my Kubota. Purchased the pump off ebay for $245. It's not oem but it is new and working fine.
Bill
/ JD 955 Compact replace hydraulic pump #3
Seems to be going around. Check for damaged hoses, lines, and filters for a suction leak before you start replacing expensive stuff. Fact you were bush hogging makes me think you kicked something up.
/ JD 955 Compact replace hydraulic pump #4
Your tractor's implement pump hangs off the back of the tractor. You
could hit it or the rubber intake hose with flying cutter debris.
However, you said the HST does not work either. That implies that you
lost a lot of fluid (or something else) since the implement pump is
independent of the HST.
It could also be an electric interlock wire shutting things down.
/ JD 955 Compact replace hydraulic pump #5
Assuming you have power beyond loop in the back, make sure your power beyond hose is well connected. I would disconnect and reconnect it just to be sure.
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
New Holland LB75B Backhoe (A62613)
New Holland LB75B...
2020 John Deere HPX615E Gator 4x4 Diesel Utility Cart (A61572)
2020 John Deere...
2004 Chevrolet Tahoe 4x4 (MPV), VIN # 1GNEK13Z24R318274 (A61165)
2004 Chevrolet...
2022 John Deere Z930M (A57148)
2022 John Deere...
