Tire Weight
/ Tire Weight #1
Mac Matthews
Chattanooga,TN
FarmPro 2420
On my Farm Pro 2420 I bought second hand, One tire has fluid in it and the other doesn't. Can I put fluid in it myself? If so how, and what fluid.
/ Tire Weight #2
You can do it yourself. You just need the proper tools and materials.
In your neck of the woods, you will have to use ballast that won't freeze. Calcium Cloride or the "beet juice" stuff.
Down here, we can get away with plain water.
Just do a search on "tire ballast" and you should get plenty of reading.
/ Tire Weight #3
a 5-9$ burp valve from napa or a farm store, plus a garden hose will get water in..
ballast as you wish.. antifreeze mixes, winter wwf fluid.. etc.. etc..
will want a tire valve tool, and for loading the ballast, the stem of a garden sprayer usually will let you pump the raw ballast into the tire before you add water.
jack tire up to take load off.
fill to 75% level
/ Tire Weight #4
. . .will want a tire valve tool, and for loading the ballast, the stem of a garden sprayer usually will let you pump the raw ballast into the tire before you add water.
jack tire up to take load off. . .
Or, you can first deflate tire by removing valve core, attach a hose to the stem, drop the other end of the hose into the ballast container, then jack up the tractor to create a vacuum and it will suck the ballast into the tire.
/ Tire Weight #5
that don't work with tube tires.. :)
/ Tire Weight
Thanks for the info. I have tube type. I'll try TSC for the valve. I assume I acan use cheap antifreeze or windshield washer solution. Would calcium
chloride be the least expensive way to go and what ratio of dilution would i use?
/ Tire Weight #7
yep.. cacl is usually the cheapest, and same omparable weight to rimguard.
bag of mix has directions for disoloution
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
2010 Ford F-550 4x4 Venturo HT40KX 3 Ton Crane Mechanics Truck (A59230)
2010 Ford F-550...
2016 KENWORTH T880 TRI-AXLE DUMP TRUCK (A62130)
2016 KENWORTH T880...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A59230)
2011 Peterbilt 365...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
iDrive TDS-2010H...
