New Member Iseki TL 4500 - loader options
   / New Member Iseki TL 4500 - loader options #1
jhmerritt
Isekyi TL4500
Hi,
I just purchased a TL 4500 to do snow blowing with a rear PTO.
I would love to see a manual for this, or any info on what loader size I could get and what models could/would fit.
Can the hydraulics present control a loader/front plow? I could disconnect the rear 3pt hitch piston and use that to go to the front.
Any assistance greatly appreciated.
John
   / New Member Iseki TL 4500 - loader options #2
Welcome to TBN. :)
   / New Member Iseki TL 4500 - loader options #3
WELCOME to TBN :)
I moved your thread to the Iseki Forum.
Hi,
May be a chocolate frying pan to some, but I did get the operators manual for this - in Japanese though. I have a friend here who will hopefully translate the main bits. If you want it I can email it through, and if I make some translations I will send that version later.
   / New Member Iseki TL 4500 - loader options #5
Hi,
John
There is no need to "disconnect" the 3pt hitch hydraulics to run a loader or blade. You can simply tap into the existing high pressure side of the tractors hydraulic supply, plumb a control valve into the circuit and on to the 3 pt hitch. Here is a link that describes how it is done. It is the same basic principal for your Iseki as with the Yanmar...just splice into the smaller line coming off the hydraulic pump. Koyker loader install on a Yanmar . If you are asking if you can simply use the exsisting 3pt valve to run the loader, that will not work, it is basicaly a single spool, single action valve.
Can't help on a repair manual....that will take some searching on the net and I'm not sure that there is even one available(?).
A Koyker 160 would probably be a good match to your tractor. I know they make mounts for the TL4200 and 4201, not sure about the 4500 so you may have to do a little fabrication for mounting.
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58216)
2014 AMERITRAIL...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
7ft Workbench (A57454)
207282 (A52708)
207282 (A52708)
KMC POULTRY HOUSE KEEPER (A58374)
KMC POULTRY HOUSE...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
