How tight are your chains?
/ How tight are your chains? #41
No doubt, installation is going to be a PITA the first time you do this.
There are some tricks to installing heavy chains. One of them being to lay the chains out in front or behind the wheels, connect a piece of rope to end of chain, insert rope thru crack/hole of rim, connect other end of rope to other side chain. Repeat for other wheel, drive tractor forward/backward to wrap chain around tire, remove rope, connect chains and install tighteners.
/ How tight are your chains? #42
Not sure? Looks like they are spaced apart about 12"-14"... They look really big and heavy! I will try to take a picture of them tonight when I get home from work and post it on here...
The standard tires on a 2520 are 36x14.00-17.5 R4. With 12-14 inch spacing, I'm guessing you have the 4 link ladder type chains...figure about 60-70 lbs per chain.
I installed chains for the first time in my 60 years, last year...no doubt, it's a job!
/ How tight are your chains? #43
On my 2520,I just jack up the rear,one side at a time.That way the wheel rotates freely,making installing the chain around the tire very easy.:thumbsup:
Greg
/ How tight are your chains? #44
Greg
thats all i do on my DK45 also. I lay out the chain on the floor and slide it under the tire. then hold it up against the tire and lock it into the thread, rotate the tire and voila....its on. then 30 minutes of fussing about tightening it and another 30 minutes setting the spring tensioniers, and one beer later, im done with that 1 tire :ashamed:
/ How tight are your chains? #45
Greg
That's a good way to install chains on smaller tractors. Might even work on large tractors if the chains don't weigh a ton.
/ How tight are your chains? #46
That's the way I've seen it done on some chain installation videos...but full sized tractors (in at least one of the vids) used the same technique you described in your earlier post:
The only difference being how the tire was rotated.
(I found several videos about tire chain installation on YouTube, BTW)
/ How tight are your chains? #47
No one has mentioned the danger of a chain coming off the tire. If a chain should break or be a poor fit and come off, you want the chain to come off to the outside. A chain coming off to the inside whilst your operating the tractor is not a good scenario. This is the best reason I know for having some tension device on the outside. Either the fancy spring tensioners as some have or a good rubber bungee.
As for loose or tight, I like just right. I think the most important thing is to fit your chains to your tire. This might mean you need to cut off and remove excess links or ladders or even reposition ladders to achieve a just right fit.
When I ordered the chains for my tractor, specific for my tire size, they came with an extra ladder installed. Why I have no idea. It was a PITA to open the links with hammer and chisel to remove the extra ladder. I also found there were excess connector links when snug so I cut those off as well. No need for excess links to be flopping around. In the end I got a just right fit and I add a good rubber bungee on the outside to tension.
Here is a pic of my new chains...
[/IMG]
/ How tight are your chains? #49
Good looking set of chains. Looks like you got them fitted up nicely. Once you do snow with tire chains you will wonder how you ever lived without them. For me it reduced my snow removal time by at least 50%. And it was a lot less wear and tear on me and the tractor.
Yeah I definitely didn't want to go for a ski ride down my driveway this year! I am going to add some bungees to the outside maybe 1 or 2 on the inside also. I still have trees to pull out yet after deer season is over unless I get one the 1stis day...
/ How tight are your chains? #51
I've got spring tensioners on my chains. I get the chains as tight as possible and then put the spring tensioners on. I also safety wire any thing that could possibly work loose. Takes a while to do this stuff each fall (I did this today) but it's worth it for me. Kind of "Set it and forget it" is the way I look at it.
/ How tight are your chains? #52
here are my chains now that the snow has melted off of them. There 2 link ladder chains. all 3/8" chain . man their heavy
Yeah they look good! Not sure about adding chains to my front tires? I don't know of anyone who has done this on a 2520??
/ How tight are your chains? #54
For my old model A that i used solely for logging and bush hogging, i added a few cross chains that were shorter in length. I then tightened the side chains tight and used rubber bungees as tensioners. The double loop logging cross chains were left loose and self cleaned very well.
Ken
/ How tight are your chains? #55
I tried plowing without the front chains on and if i tilted my blade to the side, the front of the tractor moved in the other direction. With the chains it tracks straight.
Yeah I can see hat happening very easy, now I just need someone to chime I with a 2520 that has added them on the front, clearance, etc.
/ How tight are your chains? #57
I'm thinking because the blade is out front alot farther when using the loader frame.
Wouldn't using directional braking cure that problem also?
Tom,JD doesn't recommend using chains on the front axle.Too much strain on the drive train.
Greg
Greg
Thanks Greg! I thought that was the case... I went to tractor supply looking at spring tensioners and bungees... Didn't end up buying any cause I couldn't figure out what I wanted to do? I'm thinking about putting 2-3 bungees on the inside and spring tensioners on the outside? How do you tighten yours up?
/ How tight are your chains? #59
Greg
Pushing on the brake pedals is not nearly as "precise" as being able to steer...
My front chains serve 2 important functions - ability to steer and better control the direction of the tractor and 4x4, whenever I find myself in a position when; even using the rear differential lock and rear chains, I'm stuck!
I don't routinely engage 4x4 with chains on - only when I need it.
Curious too... I didn't realize that JD "specifically" warns against front chain use. Where would I find that information?
Thanks,
AKfish
/ How tight are your chains? #60
Front chains don't over stress the frame or axle. I even checked with Kioti main office thru email, and there perfectly fine with chaining up the front end. wont affect warranty.
Their axles are plenty stout and they actually recommended it if i was plowing.
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
UNUSED RAYTREE RMH680 HYD HAMMER (A62131)
UNUSED RAYTREE...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
INOP/NON-RUNNING 2012 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL6CL455085 (A61165)
INOP/NON-RUNNING...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
