First Project Complete
/ First Project Complete #1
jmckay
Indiana
Kubota 3300 SU
Built my first retaining wall with the new tractor. Just need to let it settle a bit more and then some gravel. $3.00 railroad ties and some dirt.
/ First Project Complete #2
$3.00 RR ties. Man, you stole them. Around here they go for $10 to $15. How are you anchoring them in place, especially on that tall wall?
There is a gentleman over here that gets the used railroad ties dropped off from a maintenance crew. So it's fairly cheap, you just gotta take the good, the bad, and he will let you pass on the ugly. He still has over 5,000 ties if anyone needs any in southern Indiana. You do have to load them yourself.
I put the first row on concrete footer then the rest are anchored with 1/2" by 2' rebar. There is roughly 3 to 4 per tie. I also put dead mans in every third row up and no more than 16 feet apart. I think it was 8 dead man's in the final project and 226 rebar pieces. Couldn't have done it without the tractor.
/ First Project Complete #4
Nice work :thumbsup:
/ First Project Complete #5
now thats some nice work.
/ First Project Complete #6
I noticed the deadmans in your second pic. Those really make a huge difference in how strong it will be!!!! How did you drive the rebar in?
I bought an attachment for my SDS Max Rotary Hammer that is used for driving in ground rods. Bosch and DeWalt both make them, and it makes driving anything into the ground, or through a board, just as easy as holding the trigger!!!!!
Eddie
/ First Project Complete #7
Great Job Jmckay.....You musta had some fun drilling those out..:thumbsup:
/ First Project Complete #8
Looks like a nice job, kudos! And the price for RR ties is outstanding. Just saw some on CL here for $1/foot, which I thought wasn't too bad, considering, but nothing like $3 each.
/ First Project Complete #9
Looking good! Another project that proves the need for a tractor! Eddie what does the attachment look like, sounds very good and better than that 6 pound hammer!
/ First Project Complete #10
It really looks a lot like a socket on an extension. You put the end of it over the rod, and you have the SDS Max set for hammer mode. They squeeze the trigger and it drives the rod on down into the ground. When going through landscape timbers, I've had no problem going four feet through five pre drilled timbers without any effort on my part. It will end with about an inch of the rebar still sticking out of the timber, but that's really easy to finish off with a sledge hammer!!!
Amazon.com: Milwaukee 48-62-4091 Ground Rod Driver: Home Improvement
Eddie
I wish I would have known about that attachment. I drilled the hole then used a 10 pd sledge. After the first thirty or so I was getting my accuracy back
/ First Project Complete #12
Eddie
Sorta like a giant palm nailer. I'll have to get one of those. I don't remember if my hammer drill has a setting for hammer only though. I'll have to check. I've been thinking about building a retaining wall using RR ties along a section of creek to stop the erosion. Sure wish I could get some at $3 each. I'm still amazed at that price.
/ First Project Complete #13
Looks good, nice work. What is next on your list of things to do.
/ First Project Complete #14
Great looking Job.Theres nothing like saying ,"An I did it"
Army Grunt
2008 Chrysler Sebring Convertible (A62679)
2008 Chrysler...
3 POINT BEAR CAT 71854 WOOD CHIPPER (A65643)
3 POINT BEAR CAT...
2003 International 4300 Flatbed Dump (A62613)
2003 International...
2) 30'  42" High Pipe Racks (A62679)
2) 30' 42" High...
2014 Ford Explorer (A62613)
2014 Ford Explorer...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
