Grapple Grapple research and tentative conclusion what may be best for me; what do YOU think?
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #141
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #142
Actually, that's probably better than a pic. Thanks -- looks like a have a new project....
We let this tab extend toward the securing pin's sloped surface by 7/16", & that did the trick.
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #143
We let this tab extend toward the securing by 7/16", & that did the trick.
That was exactly what I had in mind for the repair. Glad you got it solved.
James K0UA
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #144
Grapple flap, I love it!
Jim
Yeah, it didn't occur to me how that one would roll off the tongue.:laughing: BUT it really does describe the experience of hitting a bump and having the front of the grapple fly up and then come down with a loud CLANG. Every time I'd think "That can't be good for my hydraulics...."
I was thinking I might go a little long and then grind it back to a perfect fit.
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #145
Received mine today. Rather than "shims", they sent me another set of the exact same piece that Wild Kat uses for the pin securing mount tabs. I had a local welder cut those into rectangular pieces & weld them to that take up the ~7/16" gap I had with mine. Now the pins fit very tight & they play is eliminated.
Glad you got everything sorted out and fixed! :thumbsup:
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #146
I thought about that, too, but just decided to settle on 7/16" & see how that worked. And it does :thumbsup:
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #147
Here is the fix (click on them for bigger pics):
Unpainted:
Painted:
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #148
OK... I found some stats and did a few calculations. A 10' long 12" diameter log of softwood will contain roughly 7.855 cubic feet of material. The stats I found listed softwoods ranging between 22 and 43 lbs per cubic foot. This works out to between 172 and 337 lbs per log. I seriously doubt that I would be tackling more than two logs at a time. According to this, two logs would weigh a MAXIMUM of 674 lbs. 1,150 - 674 = 476 lbs for the grapple.
Those are dry wood weights. Most logs are wet. None are dry. You should count on the average being above 43#/cuft.
larry
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #149
larry
How do you know they are "dry weights?" Naturally I took that into account but the article I read was about various "trees" (not firewood or lumber). There was no mention of moisture content so I had to assume the article was about fresh cut trees. Do you have other information?
I suspect moisture content was the reason they gave a range of between 22 and 43. so it wouldn't change my conclusion regardless. I wanted to determine the maximum weight of softwood logs.
   / Grapple research and tentative conclusion what may be best for me; what do YOU think? #150
Good question.:) ... First off my impressional experience said otherwise. -- I did some raft building as a kid and found most forest wood to be not much lighter than water [62.4#]. I found nothing that "bobbed" on the water like I would consider a 1/3 density weight at 22# doing. Nothing even that floated half way up [31#]. Best I could judge the wood logs, various and unidentified, floated 1/4 or less out of the water. ... -- So yesterday I looked for wet and dry wood weights. I couldnt find wet, but I have an old Handbook of Chemistry and Physics that has a table of "Oven Dry" weights. These numbers match what you quoted. ...Neglecting cork and balsa of course! ;)
larry
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
2001 BIG TEX GOOSENECK (A55745)
2001 BIG TEX...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
A45G DUMP BED (A55745)
UNUSED Folding 4-Step Stool Ladder (A53117)
UNUSED Folding...
2012 Dodge Journey SUV (A53424)
2012 Dodge Journey...
