Steel loop/hoop for a tow chain; where can I get one?
   / Steel loop/hoop for a tow chain; where can I get one? #11
Is there something wrong with just taking it around a trailer ball and hooking back to the chain with the grab hook? I've been doing that for years. That's only when I don't have enough slack to go around the ball and reach over to the welded on grab hooks on the box scraper. My bucket and log fork have large slide hooks in the center and grab hooks on each corner. I use these the same way as the ball and hooks on the box blade.
   / Steel loop/hoop for a tow chain; where can I get one? #12
JB4310 said:
The clevis link slips over a 2" ball easily, but not over a 2-5/16 ball.
The 3/8 and 5/16 are the same size, only thing different is the 3/8 is thicker, I thought it had a bigger opening but it doesn't.
I keep the clevis link chain on the tractor at all times with a grab hook on the other end. you can see a latching grab hook in the pic, also from aw direct.
The clevis link is perfect for tractor pulling tasks.
JB
This looks like a good method also
   / Steel loop/hoop for a tow chain; where can I get one? #13
I was going to suggest AW Direct. They have a wide selection of everything for towing and ship quickly. I've placed a couple of orders from them for chains and binders.
Ken
   / Steel loop/hoop for a tow chain; where can I get one? #15
I've always heard them called Reeving link or ring.
Reeving Ring : Transport Chains | Load Binders | Ratchet Straps | Winch Straps | Tie Downs | Moving Blankets | ATV Winch
This link as them in grade 80 because they are designed for lifting.
   / Steel loop/hoop for a tow chain; where can I get one? #16
At the risk of repeating myself: Is there something wrong with just taking it around a trailer ball and hooking back to the chain with the grab hook?
   / Steel loop/hoop for a tow chain; where can I get one? #17
Never heard that term, but I think that is euro or something, it's rated in metric tons and lists it's breaking strength, which we don't do here as far as I know. What they are calling G80 in 3/8" at 6600 pound WLL is what AW Direct calls G40 with the same WLL ?
Both specs are odd since G70 chain is 6600, G80 is higher.
They look good and solid though and a little cheaper than AW Direct
Nothing I guess, I personally never pull from a trailer hitch ball myself, for fear of causing unseen stress/ damage.
I had to go out and try that clevis ring for OP to see if it would fit the 2" ball, since I never even tried it before. But I do pull from hook adapter in a receiver hitch, the clevis ring stays on one end of a couple of my chains, since it is the easiest way to just drop in on the hook, or easy to slip the chain thru it like a choker.
Many of my chains have 2 different ends, but all have at least 1 grab hook.
JB
Hey, thanks for everything ya'll posted! Especially to JB for taking those pics showing the ring fitting over the ball :thumbsup:
Short Game: Yes, I could do that, and have, but it comes undone occasionally. Not a huge deal, but would be nice & easy to just toss the ring over the ball.
   / Steel loop/hoop for a tow chain; where can I get one? #19
...I personally never pull from a trailer hitch ball myself, for fear of causing unseen stress/ damage..
Considering that most trailer balls are of heavier construction than the chains and hooks we're considering here, I won't sweat it and figure I'm okay the way I've been doing it.
   / Steel loop/hoop for a tow chain; where can I get one? #20
Probably right, but it gives me a reason to buy all those insert gadgets :)
JB
2018 INTERNATIONAL LT625 SLEEPER (A51222)
2018 INTERNATIONAL...
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2020 FREIGHTLINER CASCADIA SLEEPER (A51222)
2020 FREIGHTLINER...
Kinze 840 Grain Cart (A50514)
Kinze 840 Grain...
2021 Acura RDX SUV (A50324)
2021 Acura RDX SUV...
