Which tractor for haying 15-20 acres?
/ Which tractor for haying 15-20 acres? #1
Gary_in_Indiana
Elite Member
Fort Wayne, IN
John Deere 4200 MFWD HST w/ JD 420 FEL w/ 61" loader bucket & toothbar & JD 37 BH w/ 12" bucket
I'm going to be haying 15-20 acres and my current tractor is too small for the job (4200) but I'm not sure how big I need to go. Admittedly, I've always been one to go one step above what is supposedly the perfect spec'ed equipment for whatever I do but am lost as to what that would be for this.
Ideally, I'd like MFWD, HST, FEL and a backhoe as that's what I have currently. I don't have a cab but wouldn't be opposed to one. I'll likely be looking at the used market for whatever I decide to pursue so your suggestions need not be limited to current models. Any thoughts?
/ Which tractor for haying 15-20 acres? #2
Before AKfish beat me to it I will ask what kind of hay equipment are you considering and what are the tractor pto requirements for this equipment?
/ Which tractor for haying 15-20 acres? #3
ok you want to hay 15 to 20ac,but you didnt say what type of baler rd or sq.so ill give you a 1 tractor for both.an thats a MX5100 HST 4x4 w/LA844 quick tatch loader.its 52hp an can pull a sq or 4 by 5 rd baler an a 8ft disc mower as well as a rake.but if you kept your JD tractor it could pull a rake.
/ Which tractor for haying 15-20 acres? #4
And do you have a price range trying to stay around?
/ Which tractor for haying 15-20 acres? #5
If your current tractor does everything you need the cheapest option would be keeping it and adding a 40-60hp 2wd utility tractor to handle the haying (5000 series). Really no need for anything larger for a small hay operation. A 40 PTO hp tractor can handle a haybine, sickle bar mower, rake, tedder, and square baler without any trouble. If you want to step up to a disc mower and a small round baler then 60 PTO hp is about minimum.
/ Which tractor for haying 15-20 acres? #6
When I baled a couple years back I used a 2001 John Deere 5410 4wd with a 541 self leveling loader. Perfect combo. 81HP and 65 PTO HP. Cut, raked, and baled the small square bales with a mid 60's New Holland baler and mower. I also tend to over kill as well. My rule of thumb is to spend as much as you can on the tractor that has the most HP on the frame that suits you best.
As others have said though what size tractor you need depends on what kind of bales you want to do and the rest will fall in place.:thumbsup:
/ Which tractor for haying 15-20 acres? #7
Also a big part is how much you want to spend!
Greatly helpful replies here. Thanks to everyone. It sounds like I may have started at the wrong end of this thing and need to look at what I want as my finished product (bale type) then determine the attachments I'll need to get that product. Once I have those first two questions answered, the tractor question will be easy.
On a side note, I have to kind of laugh at myself on this. In my business, I'm always telling customers to start with the load they want to move, then get the trailer that will allow them to do that in the manner they wish and only then worry about the truck to pull it. Once those first two things are established, figuring out which truck is needed is easy.
You'd think I could have made that analogy before posting here, wouldn't you? LOL
/ Which tractor for haying 15-20 acres? #9
You've more or less -- really nailed most everything down!! :thumbsup: Might add one more equation to the mix, though.
Has to do with hay type - grass or alfalfa/legume hay - and the amount of moisture you normally receive where you live. The answer to this can determine the type of mower and/or mower-conditioner you might consider.
Horsepower requirements for a MOCO is considerably more than either a sickle mower or a disc mower. Of course, the style of mower conditioner (roller or finger) is best determined by the type of hay you want to bale.
AKfish
/ Which tractor for haying 15-20 acres? #10
Find you an older 2WD tractor on the cheap...
Old D-17 Allis comes to mind...
Get one with a 3 pt. hitch...
Only caveat is that the gas burners use a lot but they are good tractors with good parts support...
/ Which tractor for haying 15-20 acres? #11
I do small bales on 6 acres using a 2008 Mahindra 5525 (54 hp engine, 45 hp pto, 2WD, power steering, gear tranny 8F/2R) with the ML250 FEL (6-ft wide bucket, 2950 lb lift to 10.5 ft height, SSQA on the bucket). Use old haying equipment (7 ft MF 31 sicklebar, JD 350 5-bar side delivery rake, MF124 baler). Plant oats with a restored Minneapolis Moline P3-6 grain drill (20 drops, 10 ft wide, single disc openers). Till with an old 6.5 ft wide Towner offset disc with homemade drag.
/ Which tractor for haying 15-20 acres? #12
I used to small square bale 80 acres for horse hay. It can be great fun. It can be a great PITA.
The $$$ investment you have to put out, even on used tractor and haying equipment, compared to amount of hay produced on a good year haying 15-20 acres may not be cost effective. And dont forget the time investment to cut, bale, pick the hay two to three times during hay season. All hoping the weather cooperates. The equipment doesnt fail. The 'help' shows up.
Have you considered getting someone to do the hay for you on a share basis?
Now if you have the time, the money and just want to hay yourself. GREAT! Let us know what type of hay (square/round - small/med/lrg) and we can assist in pointing out all the equipment you'll need.
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
20FT X 30FT ALL STEEL CARPORT (A58214)
20FT X 30FT ALL...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
2013 NEW HOLLAND WORKMASTER 35 TRACTOR (A62130)
2013 NEW HOLLAND...
golf cart (A56859)
golf cart (A56859)
832767 (A61166)
832767 (A61166)
