Homemade log splitter 3rd function aux.
/ Homemade log splitter 3rd function aux. #1
joulian
Member
Hey guys got a 25hp Kubota that i had a 3rd function aux. installed on this summer. Got me thinking about a log splitter now that winter is getting near.
I was thinking of making a 3 point hitch one. I was assuming all I have to do is plug it in and after i put log on splitter just walk up to front end loader handle and press it in and out.
Does this sound like a good way to go about this ?
Any one else out there do this?
/ Homemade log splitter 3rd function aux. #2
Not good. You could do that, but that is not a good way to run a splitter. You need to be at the splitter.
A log splitter valve is a good thing to have. Some of the valves, you pull the lever fwd to split/extend, and pull back to detent for return.
The auto valve will extend and return to neutral when finished splitting.
If you going to use the tractor, you would plug the log splitter hoses in the remote and bungee the lever to on, then the log splitter valve will control the splitter.
Ah ok so have to get controller.
Where can I get the splitter to mount on Rod?
/ Homemade log splitter 3rd function aux. #4
I am not sure what you mean by this.
[ Where can I get the splitter to mount on Rod? ]
Here are a few 3pt log splitters to give you some ideas.
The first splitter is using his tractor for the splitter, but not a good idea. The others have their own valve.
The second red splitter has the hyd cylinder inside the tube, and the wedge moves back and forth to split both ways.
The last splitter is using a PTO pump for the hyd.
/ Homemade log splitter 3rd function aux. #5
I think you are referring to buying a wedge. If so I think you will be better satisfied with make a plate to push the wood and making a stationary wedge. You can buy them from Northern Tool for about $40. And just my $0.02 i would spend the money for the Prince SLR 3060 valve super extend speed and lock detent just push handle for detent and forget it.
/ Homemade log splitter 3rd function aux. #6
joulian,
What model tractor so you have, or do you know the GPM's for the valve hyd?
Kubota L2500 ( Its going to be sold this coming year and upgraded to a 35-40hp )
Those are great examples in the pics you posted thanks a lot. I have the I beam already.
_________________
Yes wedge is what I meant.....thanks for info
Don't know gpm but i can find out tomorrow from Kubota dealer...
/ Homemade log splitter 3rd function aux. #11
You have a pump flow of 4.6 GPM. I would use the fast extend log splitter valve LSR3060.
Fast extend is only on extend stroke.
RK25 PERFORMANCE SERIES TRACTOR (A62130)
RK25 PERFORMANCE...
2009 Ford F-250 4x4 Crew Cab Pickup Truck (A61568)
2009 Ford F-250...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
SD Lanch SDLGC80 Electric Golf Cart (A62177)
SD Lanch SDLGC80...
Hydraulic Breaker Excavator Attachment (A61567)
Hydraulic Breaker...
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
