MT372D - Full Time 4WD?
/ MT372D - Full Time 4WD? #1
Frostbite
Fredericton, NB, Canada
Mitsubishi MT372D
Perhaps a foolish question but I just purchased a 372D (with FEL) and I was wondering if it can be switched from 2WD to 4WD, or is it simply full-time 4WD? It would be nice to switch to 2WD between tasks.
Thanks,
/ MT372D - Full Time 4WD? #2
The MT372D is 4 wheel assist. It can, and should be run in 2wd when ever possible. There is (or should be) a lever on the right, by your ankle, that when pushed forward puts it in 4wd and when you pull it back, it is 2wd.
Excellent. I tried that lever but it didn't seem to do anything, perhaps I was mistaken. I'll try again.
What is the difference between true 4wd and 4 wheel assist?
Thanks.
/ MT372D - Full Time 4WD? #4
I don't know if there is a difference, but the driveline parts (my opinion) are not strong enough to run it in 4x4 all the time. Too much binding and stress. I only lock it in when I need extra traction or if I'm driving somewhere a little risky.
The photo attached shows (just barely) show the lever in the top edge on the screen on the right.
It works now, and steers much easier BTW.
The last time I tried it I lifted the front wheels in the air with the loader and switched from 4WD-2WD, but the front wheels kept on spinning. I guess I didn't fully engage the lever. I originally thought that lever was a differential lock.
Thanks again.
HIjacking my own thread....
Is there any way to tell the year of manufacture? The former owner thought it was ~13 years old which I believe to be waaay off. I'm guessing it was built in the mid-late eighties.
/ MT372D - Full Time 4WD? #7
I don't think there is anyway to tell the true age. What color is yours? Mine is blue and it was built, I believe, in the last 2 years that Mitsubishi sold here in the states. Bill at Valley Power has a pretty good idea when these models were built. I'm no expert. Just a hobby for me.
Valley Power
It's all white sheet metal with a blue engine/drivetrain. Rims are also white. I'll see if I can post a pic later today.
You'd think they'd stamp a date on there somewhere...
/ MT372D - Full Time 4WD? #9
The lever on my S373D does not seem to disengage the front end.
I jacked it up and moved the lever around but the front wheels were still always engaged with the rear transission and will not turn on their own.
/ MT372D - Full Time 4WD? #10
duwem,
It's been a while since I looked at the 4X4 lever on mine but if I remember correctly, there is a small roll-pin that connects the handle to the shaft. Take a look and make sure it hasn't sheared off.
/ MT372D - Full Time 4WD? #11
Two bolts takes it off and that is a dry cavity. Easy to see and fix if that is the problem.
/ MT372D - Full Time 4WD? #12
duwem,
CORRECT
Happened to me on my MT180.
Easy fix, except in my case it was -25 deg and my fingers were not happy. LOL
/ MT372D - Full Time 4WD? #13
Pin in the lever intact. I'm thinking its in the linkage inside. What is this cover your refering to?
/ MT372D - Full Time 4WD? #14
On some machines (I don't recall on my Satoh) there is a plate that covers the entrance to the transmission case where the shift lever enters. The lever usually has a bent tab or bracket or something that moves the engagement fork, hub, or gear (depending on the particular setup). Sometimes those bend. I had one do that on my Yanmar YM186D, for instance. (You can see a short review of the fix here, if you scroll down a fair bit, and there is a diagram of how the Yanmar version works in post 4.)
What oliver28472 was saying is the transmission case in that area is not part of the hydraulic reservoir, so you can pull the cover without draining the fluid.
Congratulations on your new machine!
/ MT372D - Full Time 4WD? #15
Loosened the bolts holding the lever to the case and it came right off, I think I understand how its supposed to work. Looks like there is supposed to be a pin in that shaft with the hole in it in the second picture that the slot in the lever engages and pulls/pushes the shaft to engage and dissengage.
Anyone have the dimensions of what I'm missing?
/ MT372D - Full Time 4WD? #16
I'll look in the parts book and see if it's an off the shelf deal.
/ MT372D - Full Time 4WD? #17
Oliver, is your parts book a hard copy? Where did you get it?
/ MT372D - Full Time 4WD? #18
Got it from Bill at Valley Power. It includes the 373 and the 470. I think I paid $110. That includes parts, service and operators manual.
Valley Power
P.S. that was a couple years ago.
/ MT372D - Full Time 4WD? #19
duwem,
Parts book calls for 6 x 22mm in the shaft.
/ MT372D - Full Time 4WD? #20
Thanks!!!
Did you use a slotted roll pin (first picture) or a coiled pin like the second picture? Or a solid pin? Not sure if the slotted roll pin is strong enough?
Mcmaster lists the breaking stengh of a M6 slotted for 5800 lbs and the coiled pin 4900 lbs, maybe the wall thickness of the slotted is thicker?
