Pulling a trailer with your tractor
/ Pulling a trailer with your tractor #41
I don't have pictures handy now to post showing what can happen towing from a 3 point hitch raised high. When the 3 point is in position to pull a heavy pull like a plow, it is not a problem. Raise the draft links and pull having good traction. Torque of the drive tires is enough to raise the front end and keep going until something stops it. I have a picture somewhere in my files of a young man found neatly skewered when pulling a load with a trailer hooked to a drawbar between the draft links. When a trailer tire dropped into a rut the trailer stopped but the tractor rears kept going. With the pull so high, the tractor rotated until the man was stabbed by something on the front of the trailer and then crushed. I don't know about your Kubota manual but mine has several warnings to attach towed loads to the drawbar only and to use the 3 point hitch only for equipment designed for 3 point hitch usage. Remember that with these warnings in place your survivors will not see a penny when they sue.
/ Pulling a trailer with your tractor #42
Actually, it is quite the opposite.
The low hitching point LESSENS traction as less weight is transferred to the rear tires.
A higher hitching point, like a 3PH raised up a little, INCREASE traction as ore weight is transferred.
Why do yo think they hitch so high at the truck/tractor pulls. And why do you think they impose height restrictions on drawbars for said pulls???
OK - I'll re-word, as you obviously miss understood... :laughing:
The drawbar is designed to optomize traction - a higher centre of gravity may add slight traction to the rear wheels - but definately lessens front end traction.
Don't know about the US, but in the UK the height restriction at tractor pulls is for safety - exactly because the higher the centre of gravity the greater chance of the tractor going over backwards...
/ Pulling a trailer with your tractor #43
Just FYI, using one of those gooseneck hitches on the 3pt hitch is VERY hard on the top link/mount. We have one that we sometimes use on our tractors to pull a similar sized gooseneck trailer as well as a gooseneck cattle trailer, but only with light loads on relatively easy terrain. When you pull with one of those virtually 100% of the pulling force is transmitted through the top link, which it is definitely not designed for. Furthermore, the toplink mounts on the larger Kubotas are used for the draft sensing mechanism and therefore even less adapt to this kind of use.
I'm not one to tell others how to use their tractor, but just be aware of this as it is something that most people don't consider.
Being a machinist by trade I'm very aware of geometry and angles and I don't see where the top link (draft control linkage) receives any undue strain. As an aside, I lock the hydraulic valve before moving any trailer so the system is in hydraulic lock anyway. Been doing it for years with no adverse issues. I even did it with my 5030 that had no draft control. I've pulled some serious loads, upwards of 15 ton on the gooseneck from the field to the barn.
I don't see (I've watched the linkage and the 3ph out the back window) when pulling and there is no movement in the actuation linkage whatsoever.
15 ton makes the tractor smoke a bit......:D
/ Pulling a trailer with your tractor #44
It appears that we have varying opinions regarding this matter, varying sizes of equipment and varying skill levels. I am not an expert and have not had any advanced mathematic courses since high school, so it is lost in the cobwebby areas of my tired old brain. That said it still seems to be about weight, angles, velocity, inertia, traction, ad nauseum. Common sense has not been mentioned and experience with the equipment involved. What worked one time may not work the next time due to unforseen variables. We are going to do what we do and most of the posts from users that have used the 3 point hitch rather than the drawbar are real life experiences. Obviously, they have survived or someone else would be posting on their behalf. Knowing the capabilities of your equipment and your abilities is key to this the same as using any other equipment. I have been doing this for close to forty years with a series of tractors large and small with no adverse consequences to-date. That said, it doesn't preclude something adverse happening the next time I do so. I have not had any damage to my 3 point hitches to-date from doing this.
/ Pulling a trailer with your tractor #45
My sentiment (and course of action) exactly, Dan.:)
Never an issue here (other than maybe squat tires on the gooseneck.....:laughing:)
/ Pulling a trailer with your tractor #46
Very well said Dan, and of course we will all always do what works for us... My key point was simply that none of the major tractor manufacturers recommend using the 3pt to tow trailers (for the reasons I've stated), and given that they've designed and built the machines we use - they probably know best!
While you say the majority of the posts on this thread are in favour of using the 3pt linkage (I haven't counted them) - a lot of people (myself included) also smoke, but that doesn't mean it is a sensible thing to do...! If asked (as we have been on this thread) whether it is OK to tow a trailer with the 3pt hitch or if asked whether if it is ok to smoke - the answer has to be no, because both the tractor and our bodies aren't designed for those stresses! :laughing:
If the original question was whether people had problems towing with the 3pt linkage, than you and the other advocates are quite right to say that you haven't... :thumbsup:
/ Pulling a trailer with your tractor #47
I would probabally word it....
The drawbar is designed to "lessen" traction enough that there is an unlikely chance of rear tip-over.
It is simple physics that the higher the hitch results in more weight on the rear tires, thus increasing traction. Hooking to a drawbar in a near horizontal pull adds next to no weight. Raising the hitch not only tries to lift the object being pulled (less friction with the ground) but it ads that weight to the rear tires.
I know there are other dangers associated with pulling from a high hitch, and I am NOT suggesting it to anyone, but simple physics states that for MAX traction, use the Highest hitching point. Anything lower, will result in less traction. (but safer as we agree)
/ Pulling a trailer with your tractor #48
This has been an interesting discussion, lots of theory vs. practice, many good points. But unless I've missed a post, nobody has yet reported that they have damaged their tractor by towing with the 3 point hitch.
/ Pulling a trailer with your tractor #49
Say my GL3240 weights 3,500 pounds + loader + fluid in the rear tires = well over 4,000. Stats say it will lift 2,600 on the 3 point.
How heavy of a trailer would you pull behind it? I can't find the manual on line to say how much can be pulled with the 3 point. And then I have to get it stopped. The heavy loads will be off road and mostly dirt and rock, no people. Would you only pull a dump trailer with the drawbar?
I know the drawbar would be better but want to use the 3 point as it will be hooked and unhooked alot. Hook up to go dump then bring back and unhook to fill it up again. Probably with a pintle hitch.
I missed this thread, but I think it's right up my alley, just a different color.
I do exactly what you are talking about with a 10,000 pound pintel hook dump trailer.
Coupled to a 3 pt receiver hitch. works awesome, if you go heavy stay in 4x4 in low range, you'll have all the control you need.
You could use the break away switch in an emergency if you were on crazy hilly terrain and super heavy.
You do need to limit the free travel of the 3pt with a chain to the draw bar, especially for dumping the trailer as it causes uncontrollable tongue/3pt lift.
I did just what you're talking about to dig out my patio.
JB
JB
Yep, what you are doing is exactly what I was looking into. Wich I had a that nice dump trailer you have there.
/ Pulling a trailer with your tractor #51
a load connected to the three point hitch always has the possibility of "walking over" the top if the load is suddenly increased.
when the load is connected to the drawbar and the load increases it does NOT create the "walking over" since an increase in load pulls the front wheels down .. the opposite of the 3 pt hitch.
/ Pulling a trailer with your tractor #52
You could go this route if you don't have a dump trailer, make your own dumper. This is how I did it before I got the EZ Dumper
see pic.
Only problem is for me the draw bar is to low to use with the over the road trailers I have.
JB
/ Pulling a trailer with your tractor #53
That is not a simple truth. There are lots of variables to consider. I won't discuss them all, but will just give an example to prove I'm right.
Imagine a single axle trailer with the load balanced over the axle while the tongue is level. The tongue weight lessens as you raise the tongue because the load starts tipping back.
Just one example. Making a statement saying that physics always demands a certain thing is folly unless you carefully think through all the possibilities and define a limited scope.
/ Pulling a trailer with your tractor #54
Possibly??
I was really refering to pulling something like with a chain or cable or something that has a high resistance to move, unlike a trailer with a fixed tongue.
But even the trailer example can go either way. It will all depend on the trailers resistance to move. In a static situation, sure it will take a tiny bit of weight off the hitch. But factor in trying to pull the load, perhaps with a little resistance like soft ground, and the higher hitch is going to increase the weight on the tongue more so than a lower hitch.
I guess I will choose my words more carefully so they cannot be taken out of context.:thumbsup:
/ Pulling a trailer with your tractor #55
It's amazing how much stuff I learn here! I use a 3 pt hitch lift all the time, never thought about it lifting with gravity! From now on I will use a safety chain around tow bar to limit it ability to raise at the wrong time. Thanks all!
/ Pulling a trailer with your tractor #56
I use a 3pt receiver to move empty trailers all the time. The most weight I've moved was my dump trailer loaded with eight yards of mulch.
/ Pulling a trailer with your tractor #57
Just remember not to try to raise it with it chained:confused2:
/ Pulling a trailer with your tractor #58
Set the chain to stop the 3pt rise just beyond the lift limit if you are worried about feeling the resistance the chain will cause, it could bend the draw bar for sure but you can feel it before that happens.
JB
/ Pulling a trailer with your tractor #59
Sorry LD - you're missing my point...!
With a 2wd tractor, I will not argue with your logic that a higher towing point will increase traction - although from everything I have read, been taught at ag college, and seen in practice this is not advisable...
However with a 4wd tractor it will not improve overall traction. It may increase rear wheel traction, but will also reduce the additional traction available by the front wheels.
I had assumed (maybe incorrectly) that the thread was refering to a 4wd tractor... That is why I say the draw bar offers the optimum traction...
I do enjoy a good debate :laughing:
/ Pulling a trailer with your tractor #60
I think you are missing the point.
Because the same principal applies on what we are "refering" to as 4wd.
Because they have MUCH larger rear tires than fronts. SO unless we are taling about a machine with the SAME sized tires front and rear (large articulating ag, JCB backhoe, Skid Steer, to name a few) the same principals apply as a 2wd.
Because if you have a tractor like mine, with little 7x16 fronts and 11.2x24 rears, taking 100lbs off the front and adding it to the rears is going to SIGNIFICANTALY increase traction.
While the traction increase may not be quite as much as a 2wd, I'll give you that. There is still a traction increase though.
Fellabuncher Dangle head, PARTS ONLY (A62679)
Fellabuncher...
Ford 8210 (A60462)
Ford 8210 (A60462)
(2) Rolling Carts (A64127)
(2) Rolling Carts...
2009 John Deere 8330 (A64126)
2009 John Deere...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
