How can I determine my trailer's load capacity?
   / How can I determine my trailer's load capacity? #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
Guys & Gals,
I have a fellow TBN'er who wants to come over and bring his tractor (Bobcat CT122, no load in tires).
I have a 5x12 flatbed with angle iron sides, sinle axle, leaf springs, metal ramp, etc. (see pic).
I have managed to load 3 of my Harley's on it at one time, but was unable to lose tailgate so did not tow. I estimate I had at least 2200 lbs on the trailer at that point.
So, before I loan my trailer to a friend to tow a CT122 over to play tractors, how can I determine if it will actually manage this load?
I bought this trailer used and have no info on it.
Thanks in advance!
David
   / How can I determine my trailer's load capacity? #2
Go to Pro- Line's web site and look at their trailers spec. and see which one is your's and it should give you the load limites.:thumbsup:
DOH!
I never thought of that. I just assumed it was a local guy (my neighbor bought it in Georgia I think, I bought it from him years ago).
David
   / How can I determine my trailer's load capacity? #4
PS. Besure that if you do lend him your trailer that since it's a single axel that he's position the load over the axel in the proper place. Look out for fish tailing and/or too much toung weight! :thumbsup:
   / How can I determine my trailer's load capacity? #5
Does his tractor have a loader??? If so, I think it will be too heavy for your trailer.
If not, I think you'll be ok.
Just guessing, but it is probabally a 3500lb axle. Trailer probabally weighs ~1200lbs, Tractor weighs 2100lbs.
So....3500-1200=2300lb capacity. Plus ~500lb tongue weight would give you a ~2800lb capacity. Ok for just a tractor, But the loader would probabally push it if that applies.
   / How can I determine my trailer's load capacity? #6
I would not tow that tractor on a single axle trailer.
But for reference measure the diameter of the axle tube. I am guessing yours are about 2 1/3" That would make it a 3500# axle.
Figure trailer axle sizes, R and P Carriages
This chart will tell you what axles you have.
Most of the time on these smaller cheaper built trailers there are no brakes so even though they use a 3500# axle they de rate it to 2990# to keep it legal. Most states require brakes over 3000#. By doing this they build the trailer to 3000# specs. This is with the metal frame and more importantly the tires. Look at your tire load ratings.
Trailers I have sold like that in the past way about 800# empty so that would leave you with 2200# of legal capacity.
One other factor is that gate does not look up to the task of loading a CUT to me. You will bend it all up.
Chris
   / How can I determine my trailer's load capacity? #7
Chris
x2 on the lift gate.
But whats the harm in hauling a 2100lb tractor on a 2200# cap trailer using your #'s.
Whats the difference in that vs a few quads and a trail bike, or a couple of ZTR's with 4 weedeaters, 2 blowers, and a pushmower?? Or a laod of mulch.
2200lbs is 2200lbs, it doesnt matter what form it is in, as long as it cam be loaded safely with that gate.
I know we all like to go overboard here, but for crying-out-loud he doesnt need an 18k gooseneck just to pull a 2100lb SCUT
Pro-Line is merely a dealer name.
5x12 seems to not be a std size.
There is a weight lable, I can't read it, but I believe the trailer was purchased/built at Diamond C Farm Equip in Lyon's VA probably 10 years ago or so.They are out of business as far as I can tell.
Chris,
I suspect you are EXACTLY right on the weight limits. Most similar trailers I can find online are 2990.
As to the tailgate, I can take another pic, but it is metal mesh welded to a fram made of 1x2 rectangular tubing. The hinges are welded at both ends, the tail gate is removable, the pin side is on the trailer, I think there are 4 of them.
Is the mesh the weak spot, or the tubing?
Until I am healed up, I cannot climb under trailer (could not get up I fear) to measure axles.
Thanks to all of you. I am learning a ton.
David
SHHHHHHHHHHHHHHHHHHHH!!!!!
YES I DO!!!!!!!!!!!!!!
At least that is what I will tell the wife when it is time to BUY one! :laughing:
David
   / How can I determine my trailer's load capacity? #10
sorry- chris is right- the trailer you got is pretty much too lightweight for a cut tractor. your mesh gate will bend as there is no supports where tires will go.
Deere 35G (A53317)
Deere 35G (A53317)
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
9000 (A47477)
9000 (A47477)
296385 (A57192)
296385 (A57192)
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56438)
2006 Heil Tanker...
Deere 331G (A53317)
Deere 331G (A53317)
