failed grease gun hose
/ failed grease gun hose #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
while greasing my tractor I hit a zerk that was plugged or stiff taking grease, so i gave my lever gun a good pump.. was using standard #2 brown grease from napa, and gun is about 10ys old, so it's not new, however i replaced it's 6" rigid tube with a 8" whip about 6ys ago.. so whip is newer... anyway.. while greasing that stiff zerk, hose end blew out of the crimp at the gun.. hose is rated 4000 psi ( whith a higher burst ), and gun is rated 4000 psi.
have never had a grease gun hose let go at a crimp.. have had seals let go, have had ends leak.. have had an abraided hose perforate.. but never the full hose blow out of the end.
it didn't break either.. full hose came out.
in any case, screwed the 1/8 out of the gun and removed the zerk end and repalced with a new 1$ hose I got at a yard sale this weekend .. ( good timing )
had tossed the hose into the parts bin, but dug it out.. am going to cut the bad end off and use a union and hook it to a grease needle i have, and leave that hose setup that way.. I have a hand pump gun I use more often..
anyway.. just odd to see that failure..
soundguy
/ failed grease gun hose #2
soundguy
Was that an actual grease gun hose?? Most grease gun hoses I have seen are marked 10,000psi:confused:
yep.. that's likely the burst rating mine has as 10k psi, but a working rating of something like 4k.
it actually didn't burst though, the tube, in entirety, blew out of the end of the crimp.
still.. should not have done that.
soundguy
/ failed grease gun hose #4
Just a bad crimp, the weak spot in the line. I had a power steering line do the same on my truck when doing a quick uturn to go back to town for something I forgot one time. :mad:
she'll now be a grease 'fill' hose for open cavities..
soundguy
New/Unused 60in Pallet Forks (A61166)
New/Unused 60in...
2007 Honda Accord Sedan (A61569)
2007 Honda Accord...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
UNUSED ATS GAC40Y 40 GAL.AIR COMPRESSOR (A62131)
UNUSED ATS GAC40Y...
Cat CB24B (A60462)
Cat CB24B (A60462)
BOBCAT S250 TURBO SKID STEER (A62129)
BOBCAT S250 TURBO...
