ROW tire
/ ROW tire #1
tift104
south Ga.
Kubota M108 w/forestry cage, Kubota M9000, Deere 490D, Deere 550, Deere 650, Massey 383 x2, Marshmaster, Kubota RTV 900 X2,
I've been looking at putting some of the ROW front tires on my M-108 Kubota tractor. The machine spends 90% of its life in the woods plantation chopping, tree mowing, fire break plowing among other task. I'm sick of spending anywhere from $50.00 for a puncture to $500 for a used tire on the front. I'm running a 18.4/34 Uniroyal Log Stomper on the back and have not had the first bit of trouble. Running the 13.6/24 Agg tires on the front. Every time I turn around I'm having to replace or fix a front tire. Has anybody had any expierence with the retreaded airplane tires like the ROW crews use? I've tried to get a set from a local outfit here in Ga but have been getting the runaround. I know that if we go this route the rims will most likely need to be changed and I'm willing to do that. Any sugestions on the size and where else to pick them up around Ga? I know that the rolling circumference and offset will need to be as close to factory requirments as possible. I posted this on the Kubota forum but have not gotten much of a response. I fuigered that since you guys spend a majority of your time in the woods you might have some more input.
/ ROW tire #2
Have you considered foaming the tires like is often done on skid steers? I've seen tires with foam run after the rubber was coming off. Might well be cheaper than new tires and rims.
I am sure you know but if your tractor is 4wd be sure you keep the same front to back tire ratio as Kubota sent it with. If not you can bind up the drive train pretty easily.
MarkV
/ ROW tire #3
MarkV
Not an issue.
3 possible cases;
You are using 4WD because you have poor traction.
You have good traction and are using 2WD.
You have good traction, but are in 4WD - in which case you will almost certainly wreck the tractor some other way before this leads to disaster, so THIS is likely the least of your problems.
There is a fourth case, but it only applies to tractors that have transmissions able to take 4WD on good traction surfaces - work within the limitations of the equipment.
/ ROW tire #4
Well Reg, in all the years I've been reading about the importance of the "lead vs. lag" ratio when putting different tires on a 4wd tractor you are the first I can remember that says it is not an issue.
MarkV
/ ROW tire #5
MarkV
Reading about it ain't DOIN' IT, however many years you spend reading ABOUT it (-:
A few percent lead is GOOD, it helps to keep straight lines.
Any lag is usually BAD, the rear tends to run out to the side, it can be HARD to keep straight lines. You will notice it in field work for just about any task needing straight('ish) lines. You may not notice it in small confined spaces where you are turning a lot.
Zero lead/lag makes things vague, steering requires more concentration to stay straight, though at least in theory your tires will last longer due to no differential slip.
Most of us who clear snow do so in 4WD and we run onto clear dry road surface a LOT at the turn-around, it is impractical to shift in/out of 4WD every time at the turnaround, which in my case is mostly in the street.
Sure, it winds up, but it releases as wheel hop, not as transmission destruction.
Some have chains on all 4 (I don't).
Transmissions SHOULD BE able to take that - mine always have.
Again, there is only a problem if you have a fragile trans.
Same with trucks, urban legend that they will self destruct if left in 4WD, but in reality just about every truck owner has noticed an Oops, should have gone to 2WD back a mile or many ago.
Maybe they did in the 40s and 50s, before my time (-:
/ ROW tire
Mark I agree with you on the gearing ratios I don't want to cause any undo stress on the transmission or gears for the simple reason is the plantation chopper weighs around 8000 lbs when filled with water. I spend most of my time in 4wd pulling it. But I have been told that you can go either up or down one tire size from the recommended sizing and it won't effect the transmission.
As far as foam goes I've gotten a quote of $1000 per tire to have them filled. The quote I got on the airplane tires and steel wheels was $2600.00 for both. It's my understanding that the Airplane tires are 125 ply.
/ ROW tire #7
The airplane tires that I have are 16ply (Goodyear Top Flight) and hold up well BUT they are slick which means you would have no more pull from the fronts in muddy conditions. I would foam fill the ag tires and keep the extra pulling power they would provide since you will need the 4wd option in those though ROW conditions. :thumbsup:
/ ROW tire #8
I think the big jumbo jets are 125 ply and weigh close to 1000 lbs. :D
/ ROW tire
The tires I'm interested in are the ones off of the jumbo jets. They have been cut to a tractor style tread. I've done some searching and have e-mailed a few companies that specialize in that but have yet to get a response.
/ ROW tire #10
I did'nt know they could cut tread in them. If you got the time, take some pics if you decide that route.
/ ROW tire #11
GOOD GRIEF!! The woods boss tractors ( Home ) only run 28 ply tires on the front and 26 ply aircraft tires on the rear. I think 125 ply and 1000 lbs is overkill and would destroy the front end of your tractor.
Why not just contact Cobb County Tractor and see where they get those tires. They are Kevlar reinforced.
/ ROW tire #12
No air required I'm sure. I don't think a rubber filled tire would weigh that much. Kevlar reinforced forestry tires would do the trick.
/ ROW tire
Funny you said that dirt because I did call them last week. Of course I ended up getting a salesman who very quickly told me that they were strictly set up for New Holland and would not work on kubota.
/ ROW tire #14
PM me and I will give you the name of the salesman that I have always dealt with, but If they won't sell you a tire then here is another option.
Call HMTC ( Home Page ) in Alabama. They sell both NH and Kubota ROW tractors.
/ ROW tire #15
Have you checked with Toby Sexton Toby Sexton Tire Co., Inc.
They have a Recapped aircraft tire. Click on the Right of Way Mowers at top right of page. I saw a tire last week on a ROW tractor that was a recapped aircraft tire. It was a 20.00x20rim about 56" tall 26 ply . It was a rear tire and recapped by Industrail Retreaders of Atlanta,Ga
/ ROW tire
Thanks Dirt I saw that site a few months ago before I started dealing with a tire dealer out of Waycross Ga. When my deal with them fell through I started back looking for that site again and could not find it.
Hunting, I also give Toby a call and compare prices.
Looking at the tire specs shows they are running a 14.9/24 on the front of a M108. That means that I won't have to get a new rim either. I plan on getting steel centers sooner or later but had rather save every dime possible right now.
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
2001 Ford F-250 Pickup Truck (A64556)
2001 Ford F-250...
CATERPILLAR 259D SKID STEER (A64279)
CATERPILLAR 259D...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
2006 SUPERLINE DO20T192ALP T/A 20FT TRAILER (A66091)
2006 SUPERLINE...
Hypac C530AH Pneumatic Wheel Compactor (A64553)
Hypac C530AH...
