I would think you would be much farther ahead looking into a coal or pellet type boiler instead of going with an outside wood boiler.
If you research the gasification boilers the cost is right up there, but they are clean burning and extremely efficient. I believe, but not sure, that if you were to go with the gasification boilers you would also need a water storage container to store the heated water. Then it is sent to the different zones in your home. I researched them earlier but just could not justify the purchase price and space to install the unit and water storage. The company I talked with did not have a multi-fuel gasification system and did not recommend them. It is the leading edge technology for wood burning, but for our home we were looking in the low 9.000 dollar range and they had to do the installation on top of that.
Not sure what the cost of wood in your area is, but here I would have to pay around $100 a cord in
grapple load (log length). To buy wood dry cut and split I would think the cost would be around $200 to $250 a cord (that is a full cord 128 cubic feet). We cut it off the our land so it only cost me the tool purchases plus maintenance items and operating cost. We burn about five full cords a year and I have ten or so cords cut and split that has been drying for nearly two years. We are right now working on our wood for 2013 so it is an on going process to stay ahead of the heating season. Heck we do call it heating season, believe it or not and it runs from October till May.
I would suggest you check around your area and find some people that are using wood or coal for heating and see what they are using and how happy they are with it. I think some of the coal furnaces with auto loading might be a good solution as long as you have a place for storage of the coal and want to deal with the waste product. My Nephew added a coal boiler onto his oil furnace about four years ago and he only uses the oil in the spring and fall as maintaining a coal fire is difficult during warmer days. He buys his coal locally and hauls it home himself. Not an easy or clean task.
Pellets are more popular around here, but most of the people I know that have them are small in room radiant heat units and are space type heaters. They seem to work fine with outdoor temperatures down to about zero degrees F. Again here the cost for pellets is around $259 a ton delivered. Need a place to store the 50 pound sacks.
We have a Vermont Castings Defiant wood stove that is our primary source of heat. The only time we turn on the oil furnace (forced hot water) is when we are going to be leaving the area for more than one day. Our house is pretty much an open concept design so the heat will get around to all the rooms. Further away we are from the room with the stove might require wearing a sweater on sub-sero days.
Up side we do not have an oil bill coming monthly, we are really warm in the room with the stove, I keep warm many times during the winter, cutting wood, splitting wood, stacking wood, hauling it in and then hauling it out, We love the smell of the wood burning.
Down sides include the learning curve on just using wood heating, chance of chimney fires (we have had a few of them), having to plan trips away from the house to make sure we have ample wood in the stove to maintain the fire, constantly having to keep a flow of wood dry inside for feeding the stove, the list of down sides could go on and on, but I think you get the idea.
Start adding up the cost of operation and it doesn't take to long to realize that turning up that thermostat isn't to bad of a deal either. You might even consider going with a large on demand hot water heating system (propane operated and adding radiant heating to the floors if your house is a single level and you can get to the floors from beneath. You would be running low temperature hot water to the radiant floor heater elements and it would also provide all of your domestic hot water needs.
Just food for thought, sorry for getting carried away...
Wayne
