gresen hydraulic J6 valve
/ gresen hydraulic J6 valve #1
lazybum
JD 3020
I have Gresen hydraulic J6 valve controlling my Du-al loader
it has always been leaking today I noticed it looked like it was coming out of the center plug. i figured it needed an o ring
removed it an did not have an o-ring to fit
reinstalled it an it sheared right off. possibly was cracked before, because i did not put much force on it
gresen is now owned by parker and i can not find any info to get a new plug
thanks
/ gresen hydraulic J6 valve #2
How about a picture. What center plug?
Is is leaking on the end of the valve , or the port between the work ports.
Here is a pic of the valve
I also found another casting number 822
/ gresen hydraulic J6 valve #4
I believe that is your load check valve to keep the load from shifting as you move the levers.
Are those 90 degree fittings galvanized fittings? If so, not a good thing.
So where can i find a load check valve cap?
Yes they are Galvanized fittings
that is the way i got the tractor
what is bad with it and how should I fixit?
Thanks for your time and info!
/ gresen hydraulic J6 valve #6
Just remove those fittings, and replace with hyd fittings, as those pipe fittings are only rated for low pressure.
As far as the cap, you might have to get that from Gresen. It might have a function other than a cap.
If you take it to a hyd shop, they might be able to find a cap for you or tell you where to get one.
Thanks!!
It is a low pressure pump mounted on my pto shaft and all the lines on the loader are cast iron pipe too
so maybe I am safe?
phil
(1) 380/85R28 TIRES W/10 LUG RIMS (A62130)
(1) 380/85R28...
2013 Komatsu PC360LCLC-10 Hydraulic Excavator (A60352)
2013 Komatsu...
(2) UNUSED 9.5L-16 TIRES W/6 LUG RIMS (A62130)
(2) UNUSED 9.5L-16...
1999 Dodge Ram 3500 4x4 8ft. Flatbed Truck (A60352)
1999 Dodge Ram...
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
2013 NEW HOLLAND WORKMASTER 35 TRACTOR (A62130)
2013 NEW HOLLAND...
