4510 blowing blue smoke
/ 4510 blowing blue smoke #1
royabowen
john deere 4510
I have a 4510 blowing blue smoke and and will only rev to 2000 rpm. I changed the fuel filter with no improvement. Any advice?
/ 4510 blowing blue smoke #2
Cylinder compression test.
What's the history on this ?, Hrs ?, Did it happen suddenly ?
/ 4510 blowing blue smoke #4
Check the air filter. I am not a mechanic and I don't pretend to be one. I have heard that diesel engines need lots of clean air to run well.
Why does the previous poster ask about "sandy conditions."??...When I read that I thought air filter.
Hope the problem is not costly for you.
/ 4510 blowing blue smoke #5
If the air filter/intake system gets compromised and conditions are sandy/dusty it doesn't take long to ruin an engine. Check the air filter for leaks and cleanliness.
Could also be from a severely overheated engine. Could also be a mfg defect. Need to know more. Where did poster go?
/ 4510 blowing blue smoke #6
blue or white smoke coming from a diesel can only mean 1 thing unless theres something im missing.youve got a blown motor.pull your oil stick an see if theres water in the oil.if so it could be over full but im not sure.but you can drain the oil an see if water is in it.if so its got a cracked block.an time for a complete overhaul.
/ 4510 blowing blue smoke #8
A little more info and history would help. How long have you had the tractor did this smoke problem just start etc.....:confused:
NORCO MOBILE WHEEL WORK STATION (A63569)
NORCO MOBILE WHEEL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
Electric Tricycle (A64194)
Electric Tricycle...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
