Rockgod
I won't argue that 1/8 is not better than 1/4 inch but clearly there has to be some gap to avoid problems when mounting. Unless you weld or bolt something there will be play. The point with a grapple is that under load virtually all the pressure is on the top of the universal mount. The only time there would be any strain on the bottom would be going over bumps etc or when dumping the load. So long as the retaining pins are longer than the gap when locked the implement really shouldn't come out. I'd be more nervous with a 1/4 inch pin protrusion with a 1/8 inch gap than I would with a one inch protrusion and a 1/4 inch gap.
Too short of a pin would indeed be a bad thing. Luckly his appear to be just long enough.
He might be ok if he's super careful and centers his loads. With a loose fitting grapple I suspect twisting a loader arm would be much easier. Rarely are grapple loads perfectly distributed from one side to the other. Equally rare is a flat level field.
