New Kubota
/ New Kubota #1
phoenix 1
Member
Irom county, Mo.
Kubota L3800
The place where I work just got a new L3800 with FEL, pallet forks, blade and 5' bushhog!:thumbsup: I am a very happy camper.:D I have been moving logs, gravel,digging out stumps, and bushhogging every where I go. There are 102 acres and several clearings and roadsides that have not been cut is years that mother nature has been taking back, so when I am traveling from one place to another the hog is spinning away.5 hours on it in between rain and the bushog has been running for at least 3 of them. I have used every thing but the blade and it will get it's time to.
/ New Kubota #2
Sounds like you have plenty of use for it ! Use it in good health ! You are going to wonder how you ever did without it ! Don't forget to tighten the front lug nuts every once in a while while it is breaking in. I wrecked a rim and so did a friend of mine from the lugs getting lose as the paint wears off. ( according to the dealer ). Take your time and be safe. :thumbsup:
/ New Kubota #3
now thats what i call enjoying a new tractor.
/ New Kubota #4
I would say he's having a "Honey Moon " with that tractor.
Dave
/ New Kubota #5
Re-check the front axle to see if the oil needs to be topped off...
/ New Kubota
Thanks for all the comments and suggestions. I will check the lugs and fluid in the front end in the morning.
/ New Kubota
doe's anyone know how heavy brush I can mow down with this tractor?
/ New Kubota #9
It should tell you in the owner's manual of your bush hog. Some are 1inch and maybe up to 3 inch but check what it tells you. Don't not go over what it say's or you will have some repair bills on your hands.
Dave
/ New Kubota #10
That mostly depends on the bush hog. What brand and model is it? If it is fairly heavy duty I wouldn't hesitate to mow 2" diameter saplings with it. The other thing to be aware of is running over stuff with the tractor and tearing up things underneath. If it is real big brush I back the cutter up to it to mow it off. Smaller stuff I set the loader bucket about a foot off the ground and let the bucket push it over as I go. You just have to remember to not back up when doing that. Anything that you have pushed over under the tractor will spring back up and drive up into the bottom of the tractor possibly wrecking things.
/ New Kubota #11
So YOU get a new tractor and YOU get to have all the fun and someone else (the place you work) paid for it....... That's not fair to the rest of us. I need to go talk to my boss. I am sure somehow as a software tester I need a tractor
/ New Kubota
There is grass to mow and snow to be cleared isn't there? when i was working as a software tester one of the tech's and I would fight over who got to mow the grass.:laughing:
/ New Kubota
Dave
it's a Fred Cain Agri-cutter, 5' sq. The dealer is out of the manual and is working on getting me one. I was mainly curios about what size brush I could run over safely as it is a smallish tractor. I think the bush hog will probbably eat enything I safely push down. I will be seeing the dealer in a day or two to get some fluid for the front axle, it was low!:(
/ New Kubota #14
...to get some fluid for the front axle, it was low!
It takes time for the oil to seep down, that is why, RaydaKub said to do it again in a week. I would get a minimum of 2 quarts...
Tractor should handle what the cutting can cut... I would do a 2" pine but think twice if it's a 2" oak.
Remember that one "fault" with L3800 (and others like it) The steering linkage is exposed and are bent easily (don't ask me how I know:eek:).
/ New Kubota
Went by the dealer yesterday, he gave me a gallon of fluid. When I asked about the brush hog he said that the key was the shear pin, I'd know when the brush was to big when I broke it. I was been backing in when it's real thick, I have better visibility that way and less chance of running over something I don't want to. The property used to be a saw mill and there are logs every where.
Great Dane Van Trailer 1989 (A63689)
Great Dane Van...
(2) UNUSED 15-19.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 15-19.5...
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
2018 Kubota U35-4 (A64126)
2018 Kubota U35-4...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
