Antifreeze change on my GC
   / Antifreeze change on my GC #21
sweep said:
6000 hrs with the additive? That is the lifetime for majority of tractors out there. I would never trust a manufactures claims until years go by and a track record is established. The AF may last that long but how do you know a key ingrediant is lacking/used up over the years without laboratory testing??
I have seen too many claims for wonder products out there over the years and many after years of use do not perform as claimed.
Antifreeze is cheap. I change mine very 1.5-2 years. Takes around one gallon for my tractor-that $11-12 ever 2 years. Cheap insurance.
Everyone should be using distilled water also and not tap water.
That is what test kits are for. You know how much money Cat spends on R&D?? You also need to realize the 6,000 hours is 4 to 5 years for bigger operators.
They put a lot of money in to their R& D for a reason.
I will be testing what ever I choose to use. It will be pre mixed, as I am on well water.
It is only $14/4L jug, so not terribly expensive if I decide to just change it in two years.
6,000 hours is far from the end of a tractor.
   / Antifreeze change on my GC #22
I changed the anitfreeze 2 weeks ago on my GC, hadn't had time to post till now. I noticed the green was starting to gel in my overflow. Has anyone else noticed this??
I picked up my antifreeze and I am ready to change it.:thumbsup: Problem is I do not know the easiest way.:confused2: Took a quick look under the Massey and did not see a drain plug.:confused: Is there one or what is the easiet way to drain the old fluid.:confused2:
   / Antifreeze change on my GC #23
There should be a drain cock below the rad. I know there is on the 1600 series, on the right side, below the injector pump.
   / Antifreeze change on my GC #24
It should be no differant than my 1423, should be on the right side. I just put prestone in my 1423, plus water pump lube.
   / Antifreeze change on my GC #25
What did you use for water pump lube??
   / Antifreeze change on my GC #26
Yes, there is a drain on the radiator.
I just pull the lower hose off, makes draining/flushing faster.
Mine has a drain that you can see if you look on the left side (sitting on the tractor) It is mounted on the frame rail, look for a white thumb screw you will see one hose going to the block and one to the radiator.
   / Antifreeze change on my GC #28
Its call Bars water pumplube, its for anti-rust in your cooling system,
Lubricates water pump seals , protects all metal,plastic and rubber parts. It can hurt to put it in.
   / Antifreeze change on my GC #29
Finnally got around to changing my antifreeze.:eek: Put the tractor up on ramps just to make it easier to work with. Found the drain plug on the left side off the engine, when I looked before and didn't see it, it was because I was looking underneath the tractor.:confused2::eek:. Use Prestone for Diesel engine that I got on sale at TSC here in Canada.:cool:
Yup, that is the drain!!:thumbsup: Good job, easy wasn't it?
EZ-GO GOLF CART (A51243)
EZ-GO GOLF CART...
2015 Dodge Charger (A50324)
2015 Dodge Charger...
CAT 938B 2 Wheel Loader (A47384)
CAT 938B 2 Wheel...
Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K2...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52128)
Michelin CARGOXBIB...
JOHN DEERE 9650 COMBINE (A51243)
JOHN DEERE 9650...
