hydraulic dump trailer clicking
/ hydraulic dump trailer clicking #1
Sarkfishin
dump trailor Lion
Hello all,
i have purchased a used hydraulic dump trailer. i replaced the battery and pushed the lift dump button and the hydraulic pump started, sounded like it was struggling and then clicked, clicked, clicked. the battery i put in has 550 cranking amps. i tried hooking it up to my truck with jumper cables and starting the lift. but only to get the same result. Click click click. Please help me with this problem. Thanks to all who do.
/ hydraulic dump trailer clicking #2
It sounds like either the battery is bad or one of the connections is bad.
The clicking is the solenoid dropping out when the voltage falls too low.
/ hydraulic dump trailer clicking #3
Sounds like a bad solenoid, check voltage on the outgoing side of it.
/ hydraulic dump trailer clicking #4
If it is a solenoid check ebay. But beware the prices vary wildly on there. I recently had solenoid go bad on my dump also. I checked ebay and could have paid either $80 for a solenoid or $21. I went with $21 and it works just fine.
It does sound like battery issue though.
/ hydraulic dump trailer clicking #5
remove and clean all electrical connections
dump trailers take a lot of power, bad connections or a weak battery are suspect
bad solenoid is also possible
I took my solenoid apart and smoothed the contacts down to make it work again
/ hydraulic dump trailer clicking #6
I vote for bad connection or solenoid. I think 550 is small for dump trailer battery, mine is loaned out or I would look but I think it is around 750 or so marine battery.
/ hydraulic dump trailer clicking #8
I think mine is loaned out more than it is at my house.
I have a buddy that runs the local garden center and his old dump truck gave out so he has used it all summer, funny thing was I went to pick it up to haul mulch on a Sunday Morning and one of his neighbors called the authorities to tell them I was stealing it...
JRB 52" HANG-ON WHEEL LOADER FORKS (A63276)
JRB 52" HANG-ON...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
1996 Sunflower 1543-38 Folding Disk (A63688)
1996 Sunflower...
CASE 105C (A62177)
CASE 105C (A62177)
E-Z TRAIL HEADER CART (A63291)
E-Z TRAIL HEADER...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
