Bandsaw recomendations
/ Bandsaw recomendations #1
davygp38
Gold Member
where NY,NJ, and PA all meet
Kubota L4400
I find myself doing more, and more metal fabrication, and I want my projects to look more finished. I have a plasma cutter, and it does a good job on plate, but I want to get a metal cutting band saw that is big enough to cut up to 1 inch stock fairly quickly. I can't justify a top of the line saw, but something in the $600 range is doable. Any help with this will be welcome.
/ Bandsaw recomendations #3
I have a large metal roller and box brake from grizzley. there well made and weigh a ton. They dont scrimp on the steel. Have had them for several years. No issues.
As for my bandsaw, i have a basic cheap JET brand non lube bandsaw. Have had it for about 8-9 years. again, no issue and i only paid in the $275-300 range at the time.
/ Bandsaw recomendations #4
Go get yourself a cheapo Hardon Fright, Northern Tool or Grizzly cheapie (less than 200 bucks and replace the plain bearings in the bandwheels with ball bearings plus build a stand from plywood and you'll have a 600 dollar saw (minus the hydraulic downfeed and coolant ((which is reall a PITA anyway...coolant) for less than 300 bucks.
I own my own fabrication, machining and welding company and it's the favorite saw for my employees. I have a 6 grand Roll-In but they prefer the cheapie.
Throat capacity is a bit better than 6" overall diameter and it handles structural shapes plus stainless rounds every day, day in and day out.
Mine is around 8 years old, I bought for an outside job but it worked so well, it wound up in the shop. I theink I paid about 120 bucks at TSC back then.
At some point, you'll smoke the chi-com motor, it has no balls at all but the chi-com motor lasted on mine a few years before it started stinking and went in the scrap can...
Finally, you'll want to remove the fish oil in the right angle gearbox and replace it with something else with more lubrication quality. I filled mine with synthetic grerase via an alemite fitting.
Welded bi-metal bands are readily available. stay away from the carbon steel bands. A good bi-metal band like (Lennox or Starrett) will outlast a carbon blade 6 to 1. Varible pitch or straight pitch depending on your needs.
Light gage structural will require a finer pitch band than solid rounds or flat material.
You don't need to spend 600 to get a good, straight cutting bandsaw so long as you don't mind doing some simple modifications.
/ Bandsaw recomendations #5
That is true. Metal is cheap in China...they get all out scrap....:D
I've seen some really funky gears and mechanisms come from there however. I have an issue with Grizzly as far as anything with maching involved. I've seen their gears and trunions in their table saws. Powdered metal and pot castings don't get it.
I still prefer my Pexto box and pan brake and my Dries & Krump hydraulic shear over anything imported from the land of chopsticks.
Like the cheapo bandsaw I mentioned in the above post. It needs some upgrading but can be done cheaply. There is no excuse for plain bearings, or should I say no bearings in the bandwheels, especially when the blade guides are ball bearing.
/ Bandsaw recomendations #6
That JET saw you have is the one I refer to. It's a generic (everyone rebadges them) and sells them. My TSC saw is the same, but grey. Grizzly is green. Good basic saw with some modifications.
/ Bandsaw recomendations #7
Well i have no issues with scrap steel..heck all steel is made from scraps...even virgin steel still has scraps thrown into the pot.
Cast is another thing all together..that sucks. So far ive had no issues with my box brake but i am not a commercial shop. If i had to use a tool day in and day out there is no way id go grizzley. For tinkerers it fine equipment.
/ Bandsaw recomendations #8
just throwing this out there, but have you thought of a porta-band? they can be really useful at times. I got mine (a 1950s porter cable) on ebay for under $150. (including shipping) It works perfectly, and will almost last forever. Maby get a cheep bandsaw, and a used porta-band.
/ Bandsaw recomendations #9
I have a porta band also, and love it, but it doesnt make as straight of cuts as my floor model.
/ Bandsaw recomendations #10
I agree, that is the one problem. I often find the cuts have a bit of a curve to them. It will probably get better as I use it more.
/ Bandsaw recomendations #11
I have found the ONLY way to get straight cuts with my porta-band is to go real slow.
I use mine mostly for EMT pipe, so it not too much of an effort. For solid plate it might be a pain.
/ Bandsaw recomendations #12
it also might help if mine had a knob on the front, it has an old bolt right now.
/ Bandsaw recomendations #13
I bought an el cheapo used at a garage sale for $50. Just used it today to cut miters in 2X2X1/4" square tube for turning an old Kubota 3PH backhoe into a trailer mount setup. The floor models like that Jet are the ticket when you need something like a miter. My 14" abrasive chop saw would do it, but setting the vice is a real pain. The bandsaw shines for this. It's slower to cut, but you don't have to be there for the whole cut. It just turns itself off when the cut is done.
/ Bandsaw recomendations #14
I have one of the Milwaukee deep cut portabands that I use either as a hand held saw or I can put it in a stationary base that I built to do some lighter cutting and some odd angles. It is amazing to me as to the odd cuts I can make with the portaband when it's in the base. If the blade seems to "wander" it may be dull.
I also have a 14" Jepson slow speed (1300rpm) dry cut saw that works really well on straight cutoffs, much better than the abrasive blade ones.
The saw that I seem to use the most is my 7 1/4" worm drive Skilsaw with a carbide tipped metal cutting blade. You can use the Skilsaw just the same in mild steel as you would for cutting lumber and you can have the blades sharpened. I have cut material as thick as 1" with great success.
Carbide tipped metal cutting saw blades cut smooth with no burrs and they will not burn paint or powder coating and they produce very few sparks.
The next purchase for me would be one of the small JET stationary band-saws they seem to be well made and the blades are readily available. I have missed 3 of them on Craigslist in my area for about $125 each (huh imagine that) so I keep looking.
What I like about the small JET saw is being able to use it in the vertical or horizontal positions, that frees up my portaband to be portable as it was meant to be.
I have also been looking at one of the counter rotating, dual blade cutoff saws they look interesting and the concept seems sound but I really don't have a need for one right now. So I will continue looking for the JET band saw.
/ Bandsaw recomendations #15
/ Bandsaw recomendations #16
/ Bandsaw recomendations #17
I have the Wilton version of this Jet vertical bandsaw. JET Tools -
I just checked the Wilton site and they no longer list machinery, just vises, clamps, and hammers.
I have the following Grizzly horizontal bandsaw. G9742 5" x 6" Metal-Cutting Bandsaw w/ Swivel Head
I wouldn't be without either one. Pix of my bandsaws are here. https://picasaweb.google.com/110106108324823291002/ToolsPower#
I think I know why wilton doesnt list them anymore. In the URL bar of the jet site, it says JETWILTON. I think the company that owns jet and powermatic bought out wilton.
/ Bandsaw recomendations #18
This one is $850 with shipping: G4030 6-1/2" x 9 1/2" Metal-Cutting Bandsaw, but they do have some for 3-400. Would like to hear if anyone has bought stuff from Grizzly. Their stuff looks good quality but don't know personally.
I have this Grizzly:
It works very well, and I really like the swivel head feature. but the automatic stop switch engagement bolt, I never got to work correctly. I stay with the saw anyway when it is cutting and just operate the switch manually. I also added a folding handle to the stand to make it easier to move around. Overall a good saw for the money, Any bandsaw you buy will be so much better than what you are using now, you will be in heaven.
James K0UA
/ Bandsaw recomendations #19
The OP wants a reasonable priced saw below 500 bucks which is why I suggested the basic bandsaw that Jet, Grizzly, HF and NH offer for around 200 bucks and will do 99% of what he requires.
If we want to go all out, why not opt for a Roll-In. I have one in the shop and the basic model is 5 grand. Better yet, how about a Dake CNC controlled production saw. You need a big wallet there. The basic Dake is 15 grand.
You can't beat the no frills basic saw for basic home shop requirements and yes, it miters too. The hobbyist needs no more.
Flood coolant on any saw is a mess (unless you use the right coolant and maintain it). Most bi-metal blades of quality manufacture will run wet or dry. We cut stainless every day with a dry blade.
/ Bandsaw recomendations #20
on the topic of oiling the cut, there is a plate right on my porter cable that says to use wax to lube the blade. That and a lenox bi-metal blade works great.
2010 New Holland Boomer 3050 Tractor Loader (A63116)
2010 New Holland...
BUNDLE OF APRROX (20) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
2020 John Deere 2633 Disk 29' 3" (A64047)
2020 John Deere...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
(APPROX. 35) DIAMOND PLATE DBL AXLE FENDERS (A62131)
(APPROX. 35)...
LOOK! (A63116)
LOOK! (A63116)
