Rotary Cutter Kodiak Rotary Cutters? Opinions?
   / Kodiak Rotary Cutters? Opinions? #21
I do have my rear tires loaded. So I know it is over 3000.
Won't help either. Counter weight for three point hitch implements has to be as far forward as possible. If your loader by itself isn't enough, put something heavy in the bucket.
//greg//
   / Kodiak Rotary Cutters? Opinions? #22
the howse has a slot for the toplink to ride in that allows for the pivot.
soundguy
   / Kodiak Rotary Cutters? Opinions? #24
guess it's time to take the quick hitch off or build a U bracket.
soundguy
I suppose I could modify the hitch if needed. To be honest I got accustomed to my friends old bush hog that had a chain running from the top link of the cutter to the deck. That worked well, but I believe that could be dangerous. As long as I can get some pivoting at the top link area I don't think I will have any problems on any of the cutters.
   / Kodiak Rotary Cutters? Opinions? #26
should be pretty easy to make a flexilink u bracket like KK uses..
soundguy
I agree, I don't think it will be too difficult to make a U bracket. I have been planning to build my own chain guards for the front and back of the cutter. I saw a former post on here where someone took angle iron to make their guards. The dealer wants too much for something so simple.
   / Kodiak Rotary Cutters? Opinions? #29
a few pieces of angle iron, handfull of 1/4" hardware, and a truck mudflap made a great front and rear guard for my mower. cheap too. 4$ for the flap.. used 2.. 2 6' irons.. etc
soundguy
Soundguy, I had considered doing that with mining conveyer belts, but the belts are too stiff. In your opinion do you think that would work better than the chains? The chains may add unnecessary weight to the cutter depending on how big the chain links are now that I think about it.
SARLO MOWER (A55758)
Galvanized steel fence (A53424)
Galvanized steel...
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
2008 Ford F-450 Knapheide Service Truck (A55788)
2008 Ford F-450...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A55852)
2012 Freightliner...
2024 Big Tex 14GN-40D5A 35ft Gooseneck Flatbed Trailer (A51691)
2024 Big Tex...
