My Hoe
- Joined
- Oct 31, 2010
- Messages
- 563
- Location
- NYS--Various Parts
- Tractor
- Kubota B3000HSDCC, BH77, 5' Belly Mower, 6' Hyd. Angle Plow
Hi all,
I've been torn between these two tractors--the B2630HSD and the B3030HSDC.
I didn't think I'd ever want a cab, but I'm rethinking that issue.
My main concern, presently, is how much "tippier" is a the same tractor equipped with a hard cab?
I use this site frequently to compare models, such as the two I'm considering now:
Kubota vs Kubota 2010 vs 2010 B2630HSD vs B3030HSDC
Weights
B2630HSD B3030HSDC
1,786 lbs. (810 kg) with ROPS 2,271 lbs. (1,030 kg) with ROPS
I believe they are the same frame size, with just the extra cylinder and cab to account for the B3030HSDC's greater weight (a difference of 485 lbs.).
I'm concerned that this will make the tractor significantly "tippier" than it's little brother. Comments and discussion very much apprecated!
To counter-act this concern, I would like to get Kubota's 1.5" wheel spacer kit, so that the rear track can be increased by 3"--is this not possible to do, for any reason?
I plan on having a (heavy) Woods BH-80 X "Groundbreaker" hoe installed, which I understand is the "hoe of choice" for the B3030HSDC, as it's long enough (it has it's own seat) to allow for the additional distance taken up by the cab. I will have an FEL, too, of course.
I intentionally have omitted any info on my intended environment for this tractor, as we are moving and do not yet know how much land we might get-certainly no more than 8 acres, and probably much less, I would imagine.
Does anyone feel this is a "tippy" combination? I will have an FEL, too, of course.
Will the wheelspacers completely offset the added weight, in terms of the dreaded "pucker factor" or not?
UPDATE: I think I answered ONE of my own questions--I didn't realize they made a B3030HSD withOUT a cab--I thought they were all cabbed.
Kubota vs Kubota 2010 vs 2010 B3030HSD vs B3030HSDC
The weight difference is 419 lbs., between these two.
Still concerned that that additional 419 lbs. will make a significant subtraction from stability....
Thanks again,
My Hoe
Weights
B2630HSD B3030HSDC
Thanks again,
My Hoe
