3 PT boom for 3200
/ 3 PT boom for 3200 #1
Chain Bender
Kubota L3200
wanting to build a 3 pt boom for my little 3200. Should I just buy a good quality 10' stick of 2" black iron and have it bent into a 45 at about 2'X8'? How much length will I loose by benging the pipe?
Anyone have any good schematics or drawings or even better close pu pix with some good explinations of stock used?
thanks in advance.
CB
/ 3 PT boom for 3200 #2
Are you doing this project for the pleasure of working the metal or to save money on buying a boom? I ask because lately I have been seeing booms on craigslist in my area from $65 - $125. I can't think you could save much by building your own after buying the steel.
yes on both questions.
CB
/ 3 PT boom for 3200 #4
Chain Bender said:
... Should I just buy a good quality 10' stick of 2" black iron ...
CB
Black iron is really the wrong material for this project. Steel would be much better, with a gusset reinforcing any bends.
As earlier poster mentioned, you can likely purchase this complete for less than the cost of individual components.
Mike
/ 3 PT boom for 3200 #5
Here are a few pics of a store built one, one (yellow)I built here in my shop, for my 601 workmaster. I use it on my tc30 also, it works great.
Army Grunt
/ 3 PT boom for 3200 #6
Grunt, your pictures raise a few questions. How did you bend that square tubing? The angle of the tube seems greater than the 45 degrees most booms have. If it is, did you do that to get a higher maximum lift?
/ 3 PT boom for 3200 #7
Thats the angle it was when I picked up some scrap from a guy that did carports.I slid a piece incide to make it stronger.Thats a good soarse for sq.tubing. I think the bend I have will make it stronger at that point.Higher lift is allways a good thing.I mounted mine in my front end bucket a set trusses , also set.
Army Grunt
/ 3 PT boom for 3200 #8
thanks in advance.
CB
I used 2" used black iron pipe. You can not bend it good, so I used sch 40 tees and elbows , threaded the pipes, put them together and socket welded the fitting for good measure. Did not use socket weld fittings but welded threaded fittings. I have used it a bunch and yet to fail. I later added a stiffener uni-strut as I had a bit of flexture lifting really heavy stuff.
JC,
2006 GMC C5500 4X2 BUCKET TRUCK (A59910)
2006 GMC C5500 4X2...
2019 JCB 457 (A60462)
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
2015 BIG TEX 22GN -32 GOOSENECK (A63569)
2015 BIG TEX 22GN...
2009 PETERBILT 367 KILL TRUCK (A63569)
2009 PETERBILT 367...
John Deere 5101E Tractor w/ John Deere Loader (A64047)
John Deere 5101E...
