Adding Electric Circuit to BX2660
/ Adding Electric Circuit to BX2660 #1
Danner
Gold Member
Kubota BX2660
Has anybody added a fuse and circuit to the BX fuse block?
It looks like it has space, and I wonder if there is a kit or instructions.
I am adding some work lights and would like to make it fairly permanent and clean.
Thanks...
/ Adding Electric Circuit to BX2660 #2
There's already a circuit wired in for that... its in the harness behind the seat.
/ Adding Electric Circuit to BX2660 #3
Confirmed. I asked my local dealer and he said these circuits were for that very purpose. I found 2 hot wires and 1 ground back there.
Thank you guys, that is good news indeed. :thumbsup:
/ Adding Electric Circuit to BX2660 #5
On the two BXs I added work lights to, the wires were bound to the wire loom right near the 3PH top link bracket with black electrical tape. Remove the tape and you should see the wire ends.
/ Adding Electric Circuit to BX2660 #6
One other thing for future uses, alot lf these fuse boxes are already wired up for future circuits. I have found that if you pull out the fuse box, you'll see that some of the existing fuses arnt actually hooked up to a wire. They have incoming power but no outgoing lead. I guess there's a basic wiring harness and it depends on the options you order as to what gets hooked up and run.
Industrias America 435 (A64119)
Industrias America...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
2011 Jeep Grand Cherokee AWD SUV (A61574)
2011 Jeep Grand...
2012 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2012 Chevrolet...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
2018 VANGUARD REM VXP 53FT T/A DRY VAN TRAILER (A59914)
2018 VANGUARD REM...
