Samandothers
As folks say check out the easement information to see what you are allowed to do. Haying and grazing is probably alright. Building on easement is probably not going to be allowed. One reason for the land price per acre to be lower is possibly you are buying the land under the lines but are very limited to what you can do. The land under the lines is worth less than the land not limited by the easement so over all average per acre would be lower. Just has you are getting a better price because of the lines if you ever decided to sell you would get less than someone selling same away from lines.
If you determine the voltage of the line may help you to know if there will be much buzzing from the lines. The higher voltage lines may have some buzzing. Towers near my house moan and groan some in wind as they support long spans. If wooden poles they may be less noisy. I lived near a 100KV line growing up also and other than the third eye I am normal.
EMF is all around us everyday in house wiring, electric blankets etc. Electric field would drop off pretty quick as you get away from the lines. The lower the voltage he lower the electric field. The magnetic field is affected by the current in the lines and it too would drop off pretty quick. My opinion is if you build away from the line I don't think you'd have an issue.
