Bushings will not take grease
/ Bushings will not take grease #1
bww
2355 JD: 5310 JD: 444 INT: TD8H Dresser Dozer and 55N IHI Excavator
The bushings on my TD8 H Dresser dozer will not take grease. The bushing has turned and the hole does not align with the grease fitting. Does anyone know where I can get a drill bit that will drill through the bushing?
/ Bushings will not take grease #2
Where on the machine is this bushing?
/ Bushings will not take grease #3
A turned bushing is more serious that just the hole not lined up. You would be better off taking the bushing out and replacing. Or if it is still ok, staking it in solid. You really don't want that bushing to burn the hole out!
/ Bushings will not take grease #4
The bushing usually doesn't turn. What happens is the pin galls the bushing and covers the grease hole with a thin layer of bushing. Any drill bit will drill the bushing. I would drive out the pin (if possible) and and then drill. Usually after this happens the pin and bushing will wear rapidly because the fit is no longer smooth.
Bill
Lucknow 360 Feed Wagon (A63688)
Lucknow 360 Feed...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
AUCTION STARTS HERE @ 9AM (A63276)
AUCTION STARTS...
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
2008 Kubota RTV 900 4x4 Fire Rescue Diesel Utility Cart (A61572)
2008 Kubota RTV...
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
