Flooring question... Inside the house...
/ Flooring question... Inside the house... #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
Guys,
This house I live in is nothing to write home about. it is an old modular that was the dealer's demo unit. The original owners dug the basement, and move this here on the cheap. it sat out in pieces for a while and they put it up on the basement. The roof leaks, the electricity (at least the switches) are intermittant, the sheetrock has bumps and cracks, the floors are not level, etc.
I NEED to make it livable, but there is no way to make this sow's ear into a silk purse. I refuse to spend too much money fixing this place up when I will eventually (once I can sell one/both of my other homes) build what I really want up on the ridge by the pastures.
The problem plauging me right now is flooring. I did the living/dining room in a laminate wood because it needed to look good, and it wil not get as wet. The kitchen is very bad looking and poor condition linoleum. The family room (where we spend most time) is 20 year old carpet in TERRIBLE shape.
I NEED to at a minimum redo the family room in something wet tolerant. I was going to do Linoleum but the quote I just got was $3000 for the family, kitchen and hallway. NO FLIPPING WAY!
Is there a DIY option like the laminate but water tolerant? I wish there were click together plastic floor tiles a bozo like me could install on the cheap.
Please advise.
Thanks in advance,
Be well,
David
/ Flooring question... Inside the house... #2
If it were me I would fix the roof leaks. Mold is not good to live in. Then I would be removing and replacing light switches and recepticles so you do not have an electrical fire. Get some other bids on flooring.
/ Flooring question... Inside the house... #3
Just put down some cheap vinyl floor tile. I have seen those for as little as $.69 a square foot. A bucket of glue, an applicator for the glue and some scissors is about all you need. They even make it in sticky back, but I dont trust that stuff to stay put. Get the regular tile glue and go at it. Hardest part if finding a centerline and keeping it all straight but it is much easier than ceramic tile since there is no gap to align.
/ Flooring question... Inside the house... #4
Fixing a house is like washing a car...top down. Even if you throw a layer of roll roofing over what you have now it will be safer and more livable. Then you can rip out that old carpet etc and hunt down some cheap remnants, double pad underneath them and everyone will think you have a $5,000 rug down.
Jim,
The attic is unfinished, no mold. Only leaks when there is heavy wind & rain. The roof is shot. I will be re-roofing in the spring, and it is a 45 degree roof, STEEP, I will probably HAVE to hire it out. Simply cannot afford it right now after 11 months of unemployment... NO roofer are offering 0 down 0% for 60 months...
I am replacing the light switches as they are failing also. :D
I was really just trying to set the tone for what this house is like. Webought it for the 51 acres, NOT the house.
My big lovely 5,000 plus square foot house is rented out :thumbsup: so we can afford to live out in the country, with tractors and horses, 50 fowl (Guinea, ducks, & chickens). :D
Thanks,
David
/ Flooring question... Inside the house... #6
If you really want to bandage the roof and not replace it you can goober it where it leaks with roofing cement.
Gary,
Do I need to put down a layer of plywood or other ontop the subfloor?? The current subfloor is 1/2" particle board. I also have some sag in places, the floor is NOT level as best as I can tell.
This guys did all this for cash, so he seems to have been able to cut massive corners. MANY things are totally not-to-code!!!! If I posted pictures of the 10.5' wide wrap around concrete and steel porch you guys would all tell me to RUN AWAY fast...
But this is what I've got, I bought it (I was planning to do a full remodel from foundation up and suddenly congress cut my contract to $0).
I am just looking to make it livable.
Thanks,
David
Fixemall,
Where I can find it, and it leaks every time, I am doing that now.
Maybe it is better to say occasionally the roof seeps water, depending on wind direction and speed, and qty of rain. It does not always leak in the same places.
Plain and simple, the best way to fix this house would be a bomb. but I can't do that... :D
David
/ Flooring question... Inside the house... #9
Actually, they do make water-tolerant laminate.
If you have a "wet" problem, I would not recommend vinyl until the water issue is resolved. Is it possible to just cover the roof with a tarp where it leaks?
If you do use vinyl tiles, two things:
1) I agree that the self-stick tiles need adhesive like the commercial type. However, make sure you use the right adhesive. It is made for vinyl tiles and is different them sheet goods adhesive. When you apply it, you have to let it "tack-out" - in-other-words you have to let it sit open until it is dry to the touch or the tiles will not stay in place.
2) When you put the tiles down, make sure you have them right because they do not come back up easily. Also, do the edges last and they are the trickiest to do.
You do not have to do the whole floor at once if you want to take more then one day. Just don't glue more area then you can do in one sitting.
Qapla,
The "wet" problem for the floors is wet shoes, coats, and kitchen wet. It is also my Wife LOVES her steamer mop.
The roof leaks are contained in the unfinished attic. Nothing reaches the floor.
David
/ Flooring question... Inside the house... #11
You said baesment ... can you post and beam the floor joist to level the floor in that room? If the subfloor is sagging not the joist then maybe overlay. Sticky tile, they didn't stay in place, I wouldn't use them.
That laminated flooring is some pretty tough stuff.
/ Flooring question... Inside the house... #12
If its low spots in the sub floor and not sagging joists, you can get self leveling cement to bring up the low spots. Talk to the tile guys at your local home improvement store.
/ Flooring question... Inside the house... #13
homedepot has linoeum the type that look like wood that are self seal to each other and not to the floor so you dont need to buy extra glue it work great in my bath room
Kerry,
So they float like Pergo and only attach to each other, NO GLUE?!
That sounds almost PERFECT!
David
/ Flooring question... Inside the house... #15
Kerry,
David
They no workey if you have big sags, the fastening edges break when you walk on them, tried that in one of my rentals and ended up having to use 10 gallons of leveler to get everything to stay put.
Cant post and beam. it is not joists it is sloppy workmanship.
The basement though is somewhat of an engineering marvel. 1340 square feet with no posts. The steel I beams holding up the house are HUGE and there are two extra beams perpendicular to the main beam, there is no sag unless the steel is sagging...
This guy was a welder/iron worker (you will not believe the scrap metal that I keep finding all over the property).
David
/ Flooring question... Inside the house... #17
David
Okay ...if the joist are good and level and the subfloor is sagging may need to overlay with plywwod first. What centers are the current joist?
/ Flooring question... Inside the house... #18
Good idea ... if the current subfloor can support the added weight.
16" center the joists are (measured) 1.5" x 9" (I've never heard of 2x9's?).
Honestly I think the level issues are sloppy workmanship, not sag.
Also the cieling is already only 7'4" and I can't stant the idea they will get lower...:)
David
/ Flooring question... Inside the house... #20
You might try Lumber Liquidators They have a nice array of flooring options. There is a vinyl flooring laminate that is interlocking just like the "wood" type.
(7) DONALDSON P600676 AIR FILTERS (A64276)
(7) DONALDSON...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2013 GMC Sierra 2500HD Ext. Cab Knapheide Service Truck (A68183)
2013 GMC Sierra...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
2017 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65056)
2017 CATERPILLAR...
