n00b HYD quick Connect question
/ n00b HYD quick Connect question #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
So... I am struggling with my quick disconnects mostly because I am 90% one handed due to carpal tunnel surgery last week.
But the n00b in me NEEDS to know the following...
Q: If I turn off the tractor is it easier to changed the quick connects? MUST I turn off the tractor? Must I also AFTER turning it off work the levers to relieve the pressure?
A: ?
Right now it is taking me like 5 minutes just to get the 2 hoses for the grapple connected (using only my left hand).
Thanks in advance.
Be well,
David
/ n00b HYD quick Connect question #2
A: ?
Thanks in advance.
Be well,
David
David here are my thoughts: Yes you should turn off the tractor, and work all the levers to "settle" the front implement on the ground. If there is tension in the implement, lets say like the loader bucket settles some more after disconnection it will be harder to connect again as the pressure in the hoses can rise while disconnected from the movement compressing the cylinders. Now that said the pressure can rise anyway if the implement sits in the sun and soaks up heat. If you relieve pressure by covering the coupler end with a rag and pushing against a wooden object or hitting the ball (gently) with a wooden or plastic object (to relieve pressure), it can make reassembly easier. Of course you one-handedness is mostly your problem for now. Brute force and ignorance will always prevail:D One thing you do not want to do is hit the ball end with anything metal or with any grit on it. The rag is handy to keep from taking a bath in hydraulic oil too.
James K0UA
/ n00b HYD quick Connect question #3
There are some QD's, that have the push/pull sleeve, and it allows easy hook up with one hand.
J_J,
Mine look like the attached pic.
Tell me the secret sir! I will FOLLOW directions, I PROMISE! ;)
David
Hmmm... Try this pic...
/ n00b HYD quick Connect question #6
Actually there is no secret. Sometimes you just have to fiddle around with them until they connect . If it is not pressure causing the problem, it is the fluid on the fittings, making them slippery. The heat will also cause problems with implements left in the sun, but there are ways to prevent the pressure build up, such as making up a dummy plug for the QD. The fluid just expands into the dummy plug setup.
Some QD will connect with low pressure, and others will connect under operating pressure.
/ n00b HYD quick Connect question #7
I believe I would put a 90 or a 45 degree fitting there so as to relieve the stress.
J_J,
I changed the back side to 90 degree to prevent the breakage I had.
I am sorry the picture is cropped, but I believe they are already 45 degree on the QD side...
Not sure I understand how that reduces pressure though...
David
/ n00b HYD quick Connect question #9
David, You have an electric diverter valve to operate the grapple correct? if so need to shut off the tractor then trun the key back on, push the diverter button then move the joystick left and right to release pressure in the grapple connections. Just moving the joystick with key off will only release pressure in lift & tilt. They should disconnect fairly easily one handed, hooking backup is still a challenge, but be easier with pressure released in grapple.
/ n00b HYD quick Connect question #10
I think he has the true 3rd function valve, but regardless, your point seems valid to me, he should press both buttons each in turn with the key on to relieve pressure. Worth a try anyway.
James K0UA
James K0UA
I believe I have a WR Long 3rd function valve. Cost me $800.
There is an electric valve assembly under the tractor near the seat mounts I think.
David
/ n00b HYD quick Connect question #12
J_J,
David
A lot of fitting will reduce pressure somewhat. Some more than others. Far instance, a 90 degree fitting will reduce the pressure, but two 45 degree fitting will reduce the pressure even less. Just a couple of fittings will not make a big difference.
2011 Bobcat E50M Mini Excavator (A61567)
2011 Bobcat E50M...
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
(INOP) 2003 KYMCO MX 150 ATV (A62130)
(INOP) 2003 KYMCO...
UNUSED WOLVERINE TDB-11-78W 78" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
