High Tension power lines
/ High Tension power lines #21
We pastured horses under the line. When the power company wanted to do maintenance they would send someone to the house a week prior and make arrangements to enter the property with the least amount of disturbance to the live stock. These guys were professionals and knew what they were doing.
They really are great neighbors. They use helicopters to check the lines here and when they get to our pasture they stop short and fly around the pasture instead of flying low over top of the animals. They always go out of their way to keep the adjoining land owners happy.
/ High Tension power lines #22
We have transimission lines at along the edge of our property. We have pasture under it. We have never had a problem. The power company only needs access, we keepo it mowed. They did build a great gate in the fence line between my neighbor and me.
/ High Tension power lines #23
We have a transmission line about 250' from our house. No noise or any other TV/radio interference. I believe that noise, etc is more prevalent on 500 KV lines. The lines by us are 340 KV. Other than the tower being a bit unsightly, no issues in 25 years. Power company keeps it nicely trimmed. No ill effects from the supposed health risks. Also it is extremely rare for lightning to hit, since the lines are grounded (two small highest wires) which intentionally create a ground field around the wires, to prevent strikes. We get a few strikes a year, but in the woods 500'-1000' beyond the house. Never anything close in 25 years.
paul
Ive never seen lightning hit any of the towers (metal or wood). I did see one of the metal towers arc. Well, I describe it as an arc. There was a lot of static (well thats what it felt like) in the air as the weather fronts were changing and the lineman we talked to explained it to us that under certain conditions the lines do arc. It made a very wonderful noise and a huge flash of light but nothing was affected by it. The lineman on here would probably explain it better but I've only ever seen it happen once but it was spectacular. The noise it made building up to the boom drew our attention. Other then that the set of towers (what we call the second power line) looks just like the one the OP posted makes a buzzing noise. Its a double line built with wood posts and the noise is worse when its raining. I've built a tower stand right off the right of way but I have been so use to that noise you don't even think about it anymore. Plus the I90 is right behind the tower (50 yards) so that noise pretty much eliminates any line noise.
/ High Tension power lines #24
Also, I always looked at it like this, if they own the land and you are allowed to use it then who cares if they go through it and leave a rut. Its not your property and any damage would easily be fixed if it mattered.
It is your property...you or the previous owners just sold an easement. I'm not familar with NYS laws, but I wouldn't be surprised if you're paying property taxes on the property.
An "advantage", if you will, is it gives you a good reason to protest a higher assessment.
Again, I'm not familar with NY laws...
/ High Tension power lines #25
My place has single set of high tower 14,500 volt lines down it see it here
http://maps.google.com/maps?q=76+CO...0.010568&vpsrc=6&gl=us&hnear=U.S.+30&t=h&z=18
the brownish strip across the corner is the lines. in 10 years they been through 2 times and did some tree removals and left a mess. I wasnt there when they came through but did get notified about it. once just after the big blackout that started due to tree to line grown up. they made a pretty big point after that of clearing most of the rightaways better. they came through last spring and hacked & sprayed some of my planted x-mas trees and I should have made them pay for them... 30 christmas trees in the 6~8 foot high are expensive. you have right to maintain any crop under them that is less than 10' here. mine are usually quite but every now & again you can hear them under the right conditions.
looks like that is a ATV/LOGGING road under the lines. the price is good about what I paid for my 22 acres 10 years ago, but I got 3 out buildings well & septic all in pretty cheap due to the power lines. looks like mature woods that could be logged off there & make more than the buy price but like me I want my logs to stay trees...
I say go for it. only issue may be getting back into the property to build and get power and well in. I would build a drive under rightaway using the road back 3/4 onto the property then head back to the property line to hide in the woods myself. you could fence off the right away along the line to keep pasture critters in or grow garden ect... stopping the atvs and non-owner access is not an issue for me but maybe for you there.
mark
edit in: here we own the property they have "right of way" which gives them the right to maintain and access it but we can plant grasses harvest any crop even trees as long as they are lower height than their right of way height standings. no permeate structures ect. also no parallel wires / fencing as it will generate electrical current thru the wires.
/ High Tension power lines #26
No, its not our property. The power company owns the land under the lines. Our property stops at the line then starts again on the other side.
/ High Tension power lines #27
We have similar power lines that run across a corner of our land and most of the negatives have been mentioned (buzzing noise, static shock are the main issues we notice)..
Before we bought the property I researched it quite a bit and the only 'proven' issues was in CA with young kids getting cancer - BUT the kids lived directly underneath of the lines. the power company has a 100' right away from the center of the lines, so that would never happen.. BUT when you think of it, what in CA hasnt been proven to cause cancer.. hehe
b
I will have to do some more checking but the way the property is shown on the realtor website with property lines, it appears that I would own the land under the power lines and that the PC would have legal access- around here it generally referred to as an "easement" but I think "right-of-way" would be correct as well- but of course I'm no lawyer so there is probably some legal difference.
Weesy
/ High Tension power lines #29
Weesy
Technically it is your property as to the rights to sell it our use the ground within the limitations of the easement. I would read the limitations carefully and be comfortable that it wouldn't interfere with any possible improvements that you may want to make later on.
/ High Tension power lines #30
Weesy
I'm not saying its that way every where. But I don't own any of the land under the power lines. They came through before I was in this area and I remember talking to my neighbor and he told me the process of when they came through and bought the land they needed which split up everyones property. Didn't really change anything other then you have some towers every so often and have less ground to pay tax on.
/ High Tension power lines #31
I am sure this could be different in other areas. The way it was explained to me by the power company where we live is that we still owned the land but by accepting the cash settlement for the easement we had to abide by their stipulations on the restrictions of the easement. It was our land but the power company had total control of how this easement was to be used. I never really felt that this was our land after the easement went through. I guess its all in how a person perceives ownership.
/ High Tension power lines #32
Perhaps you've already done this, and if so, my compliments for your wisdom, and you can disregard the rest of this. If not, or to anyone in similar circumstances, my suggestion is to get with a good attorney who specializes in zoning/development laws in your county. You first need to know if you can even get a building permit for that property.
The reason I suggest this is that if the price is well below market value, it may be for a reason you are not aware of. For example, your county may now have minimum road frontage requirements in order to get a building permit. Or they may require more acres than the size of the property you're considering. These are just a couple of things that could stop you from building.
If it sounds too good to be true, there may be a reason. Good attorneys are not cheap, but they are well worth it if it keeps you from making an expensive
mistake. Good luck!
GGB
/ High Tension power lines #33
I hear the new strains of Roundup ready alfalfa do really well under high voltage transmission lines. The hybrid is stimulated by the electricity.:laughing:
/ High Tension power lines #34
I grew up under some 69,000 Volt lines and there is nothing ,nothing ,nothing, nothing, nothing wrong with me!;)
James K0UA
/ High Tension power lines #35
In many states there are differences between easements, rights of way and servitudes and they are defined different ways in different jurisdictions.
On my property, the power lines are on a 150' easement, the railroad tracks are on a 200' right of way and I have a 10' drainage servitude on the rear of my property. If I ask 10 different people what the difference is, I will get 10 different answers. :confused2:
/ High Tension power lines #36
In my deed, a timber company has the rights to drive horse teams across my land. It has been there since the late 1800's. But no mineral rights, but nothing down there.
/ High Tension power lines #37
KOUA,
Is that evaluation of having nothing wrong with you, nothing! nothing! nothing! your evaluation or is it the confirmed feeling of medical professionals? (Laughing!) Living your life under 69,000 volts is something that few of us experience. By they way, my comment is entirely in jest and I presume your personal evaluation of nothing wrong is probably right on.
Years ago I made hay on a 35 acre piece of ground on which we farmed directly below some very high voltage lines, I don't know what the voltage was, but the wires were suspended in three sets of three wires each that were also separated from each other by a triangular device that provided approx. 3 ft of separation between the three wires suspended on each of three support arms on each tower. There were two rows of towers set side by side. To the best of my knowledge, these transmission lines were part of the main north south inter tie system between Bonneville Power from the dams on the Columbia River and a connection that fed into California.
I was told that depending on the season of the year and the time of day power was routed over these lines north or south to provide energy as the demand changed in any given area, air conditioning versus heating often being the determining factor.
When working directly below the lines they were usually silent and you pretty much forgot they were there. At certain times, for instance, in summer in mid afternoon, the lines would begin to crackle and make buzzing/low tone arching type noises. Later in the afternoon the noise level increased and the lines would begin to slowly sway back and forth even though no wind was blowing. I am not sure if we imagined it or not, but it seemed like we detected a sensation like the hair standing up on your arms, head etc., during the time that the noise level was the highest and there was noticeable swaying of the lines.
We worked around and under those lines only a few hours each haying season and as far as I know, just like KOUA I am not aware of any detrimental affects from the exposure to the hight voltage transmission lines.
I never did get concerned about it, but my exposure was very minor and in those days you tended to assume the people in charge of things like power lines would be sure to prevent any harm coming to their neighbors. As time has gone on, that may have been proven a poor assumption.
To button this thing up, I also would recommend a thorough research of the most recent understanding of the affects of high voltage on you, especially if you are potentially putting yourself in a situation involving long term exposure to high voltage electric transmission lines and facilities.
The best of luck with your new property and heres hoping the transmission lines are much more a positive factor in the acquisition of and utilization of the property, especially when the lines might help keep the purchase price down and you would still have a great property to enjoy for many years.
Nick, North West Farmer
/ High Tension power lines #38
James K0UA
So ... a freak. :)
larry
/ High Tension power lines #39
So ... a freak. :)
larry
Just because I have 3 eyes, in each of my 2 heads I don't see why you should be calling me a freak.;)
The 69000 volt lines were probably 250 foot from the house. I never really noticed them much.
James K0UA
/ High Tension power lines #40
That one is really high potential. The main intertie has been a million volts since the '70s, and can handle a large portion of the energy output of the mighty Columbia. I can't imagine how many million horsepower was running down those wires. It's no wonder they crawled around a bit under heavy load.
