Is it normal practice to provide work-port RVs on both the bucket and thumb cylinders? On industrial hoes, anyway? /quote]
As far as I know it is. The construction backhoes I've looked at seem to have relief valves everywhere. Not just on the bucket and thumb cylinders, but on every circuit and in both directions. I'd have to go out and count, but I seem to remember that our Kubota
M59 has 8 relief valves on the standard backhoe spools plus two more when the thumb was added.
Doesn't it increase the hose pressure when two cylinders are working against each other?
My hoe has only 4 shock RVs for the 6 valves it came with, as I recall. Six
valves on a typical hoe (without hyd thumb) means that you could have
a total of 12 work port reliefs. It makes sense that industrial/commercial
hoes would use RVs everywhere.....the pumps are so fast that huge
kinetic forces build up to be stopped in an instant by the valve.
The
L39/
L45/
L48/
M59 all have dual-pump hoes, so each independent
system would have its own pump-RV, too. Dual pumps also allow you
to put added valves (hyd thumb) on either circuit. If the thumb valve
operates off the swing pump, then you could have the bkt push
against the thumb in an active manner, so the element putting out the
greatest force would push the other back. So when both valves are
on, the internal pressure could not be greater than the pump-RVs of
each pump. If one valve was off, and the other element was pushing
on it, then the internal cyl and hose pressure could definitely go
higher. I try to design for it.
You can also activate the bkt and thumb in parallel with a one-pump
hoe by pulling both levers at the same time, and then one element
pushes and moves the other, like a
grapple.
