pressure washer 2700psi
/ pressure washer 2700psi #1
koffee
my pressure starts fine , but when you press the trigger it stalls.I have plenty of water pressure.
/ pressure washer 2700psi #3
what kind of washer is it? There a a lot of videos on youtube showing how to trouble shoot this kind of problem.
/ pressure washer 2700psi #4
multi possibiliites.
air in the water house feeding pressure washer. it can take time for the air to move out.
you say pressure but how much pressure? if you are on a well. then good chance you may not have enough pressure. well's for regular homes tend to be set at a lower pressure rating. vs folks in cities were pressure can be much much higher.
pressure is only one factor. gallons per hour. or rather flow rate. you might have 60PSI at the garden house feeding pressure washer. but if there is a kink in garden hose. or using cheap smaller size garden hose, and have a old home with metal pipes that have corrosion build up. you may only be getting a trickle of water, vs say 2.5gph to 20 gallons per hour. or more.
garden hoses come in different inside diameters. the larger the diameter the more likely better off you will be.
you might have some sort of screen on the inlet side of pressure washer were garden hose hooks up that might be plugged solid with stuff.
2006 Mack Kill Truck (A64194)
2006 Mack Kill...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2022 EZ-GO ELITE...
New - Front mount rototiller
New - Front mount...
2019 BOBCAT E26 EXCAVATOR (A63276)
2019 BOBCAT E26...
SHOPBUILT S/A TRAILER FRAME (A64278)
SHOPBUILT S/A...
