Chains for BX
/ Chains for BX #1
Bota Bum
Who has snow chains on their BX, and if you do, did you find any clearance issues.
I have a BX2360 and I wish to install the V bite type chains on 2" links and want to be sure I do not run into clearance issues, especially on the front.
Thanks!
/ Chains for BX #2
Try www.tirechains.com.
Be best if you know your tire sizes and type (ag, Industrial, turf) before you call.
/ Chains for BX #4
I have chains on my BX23 and it was a tight fit. Last year the chains loosened up just a little bit driving at full speed down the country road and started hitting the lever that shifts from the front PTO to the rear PTO. I never use the rear PTO so I just unbolted it. I added wheel spacers and it now has plenty of clearance all around. I leave the right spacer on all year and I have to remove the left side spacer to get clearance for the 60" mid mount mower.
I had listened to others who said chains aren't necessary on the BX but once I tried them,they go on in the fall and don't come off till spring. With the bar tires it is phenomenal how much traction you get. I do mostly plowing but when the snow gets really deep I have a front blower.
/ Chains for BX #5
This is my rig, no issues besides fantastic traction. Just have to make sure that the front chains are TIGHT.
/ Chains for BX #7
What are those disc looking things on the outside of the hubs?
Wheel weights...for more traction. They look like old cast iron weights from a free weight set to me.
Can't get a lot of liquid fill in those small tires of the BX series tractors.
/ Chains for BX #9
Ah ha..... would this help in the dry?
Depends on what you're doing. They help with loader work (but ballast on the 3PH is better, IMHO). They also aid in stability of the tractor.
Might not be so good if mowing is the primary function of the tractor though.
/ Chains for BX #11
Those disc looking things are custom wheel weights and are not from a free weight set. I couldn't find anything on the market for my bx that was worth anything. The cheesy little weights that kubota sells are hardly worth the effort of putting them on the tractor.
So having been a pattern maker for some thirty odd years I decided to make my own, I made the wooden pattern and then sent it to the local foundry for casting. The weights fit into the rim all the way to the lug nuts and weigh in at 225 pounds per side.
Yes they do help in the dry, I never remove them, but because of the weight I had to build a metal stand on wheels to install them but as I said I never remove the weights I have only used the stand once.
The boys at the foundry gave them a shot of black spay paint which has sorta worn off working in the bush, maybe I should repaint them sometime but my tractors are working tractors and not there to look pretty.
David
/ Chains for BX #12
OMG (hands covering mouth!) 225 lbs/side. I assume you did both front and rear.
Does all this weight have any negative issues? I know mileage is not a concern on a tractor but I wonder if you'd notice increased fuel consumption. I've gottten myself into a few situations that the increased weight would have helped. How do you attache them? I'd imagine it would make the ride much more stable.
My neighbor keeps telling me how he added some type of liquid to his tires to increase the weight. It's a big 4200 unit with large times.
/ Chains for BX #13
I haven't found any negative issues using the weights, only positive ones. Fuel consumption is really not a concern, traction and stability are.
As for the front I would not put weights on the front wheels, I did however make a 225 lead weight for the front bumper. It's ugly but it works well to keep the front end on the ground when using the loader. At 225 it's still 50 pounds under max for the front end but it works.
David
/ Chains for BX
Concordriver, thanks for the pics. My concern was the front end and you seem to have no issues. Roy, I will be buying form the source you offered here in PA.
Thanks all!
/ Chains for BX #15
David
David, that's the second time I've seen you talk about weighting the front end for loader work. Are you saying that you keep the wheels down when you are digging? Otherwise, my front end is plenty heavy just with the loader weight itself. I would think a backhoe would benefit more than a FEL from a front bumper weight.
/ Chains for BX #16
Yes RaydaKub I do a lot of digging as in digging out field rocks and making rock gardens. Without the front weight the front end just lifts, lets face it these bx's just are not very heavy anyplace and are mostly made for mowing grass but with a little tweaking they can be made to perform like a much larger tractor but in much smaller spaces and that is where I need the bx as in landscaping. Without the added weight when that bucket touches the ground the front end has virtually no weight and will come off of the ground especially in heavy soils like we have around here.
As far as the backhoe I don't have one for the bx as I don't have much use for a backhoe of that size, when I need a backhoe I bring out a real machine from my business like a Cat 416E Backhoe Loader.
David
/ Chains for BX #17
I had chains on at first with fel and rear snowblower, than took them off and had no problems. I had a small hill and went great. Have fluid in tires. Turf tires do better in snow than others. The chains are for backup now.
/ Chains for BX
I'm doing the chains, more from a safty standpoint than a traction need. By that I mean, my BX is new to me, I have no clue how it will handle ice. My gravel drive, on a good hill, gets icy. I want all the grip I can get, not find out in the middle of sliding down it I should'a have got chains for it. I'm putting them on, upfront. I plow with a Silverado and Curtis 7 foot setup, the BX is to aid where I cannot get the plow to, or clean up snowbanks. Last year with all the snow, I ran out of places to push it, the banks got too high, and, too hard to move once they froze solid. Hopefully this year, will be light on the snow, as here in the NE PA, we have had a record year for rainfall. The weather guys say, in record years of rain, once the cold sets in, the pattern should shift and preciptation, should decrease, below normal. I am hoping....
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
2012 International 4300 Reefer Truck (A63689)
2012 International...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
GATOR UTV (A63276)
GATOR UTV (A63276)
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
