HST Wine, Not any more
/ HST Wine, Not any more #101
What if you filled with foam in "lifts"? Fill the bottom, then let it cure and add 4-6" at a time on each side until you hit the top?
Aaron Z
/ HST Wine, Not any more #102
Aaron Z
That idea has some merit. If you put a small tube of pvc up from the bottom, you could still add wires any time (at least up to the curve). But what you may discover is that if you filled in like 12 inches on each side, you don't need any more; the resonance would be dampened already. OK, maybe 12 didn't do it, but 18 would...
/ HST Wine, Not any more #103
What if you took a piece of material (lets say plastic) and cut it to match the ID of the rops, put a piece of conduit through it and pushed that down to just before the curve (I am thinking the belled end of a PVC conduit on the "top" or curve side to keep it in place)?
Then it would allow you to leave the top/curve area unfilled and give you a conduit to that area. It would fill the sides which is where the resonance probably comes from.
Aaron Z
/ HST Wine, Not any more #104
Sand is used in audio to fill the hollows of some speaker stands. I would think that you would not need to fill the entire ROPS but just the lower section. This might be enough to change the resonance frequency and make a difference.
On another note: If the spray can stuff does not finish curing only in the center and the outside is a skin...what is the problem? The skin will protect the metal right? Who cares if it has a liquid center?
Just my rambling...
/ HST Wine, Not any more #105
the problem with sand in a metal tube, which causes condensation when exposed to changing temperatures. Freezing and thawing and then rust unless its a good quality stainless.
/ HST Wine, Not any more #106
How about a granular desiccant, then weld the hole back up and seal the cavity. Sounds like an expensive proposition though.
I'm back to the anti-freeze or something similar with corrosion inhibitors in it.
Ian
/ HST Wine, Not any more #107
Ian
I still think fishing 1 or 2 runs of 3/8 or 1/2 nylon brided rope is all that would be needed to damp the resonance - and no worries about leaks, moisture or future fishing desires in the tube.
/ HST Wine, Not any more #108
Well I added the 1/8" rubber gasket. Can't hear a difference.
Ian
/ HST Wine, Not any more #109
Ian
Percentages of 1/8 inch compared to tube size is too small. If you are using 1/8 inch, you'll need 4 to equal the impact of 3/8th, or 6 of them to equal 1/2 inch.
/ HST Wine, Not any more #110
In re-reading the original message I may have errored in my reply to it. If you mean you placed a layer of 1/8 inch of rubber between the rops bar and the tractor, you haven't effected the "tuning fork effect".
IMO it has to be either IN or AROUND the rops bar. Sorry if I misunderstood.
/ HST Wine, Not any more #111
I used to work in polyurethane (foam) roofing. That operation had a guy in the shop that also did tractor tire fill. Mostly for Mobil home assembly lines. The workers would put a nail in the tractor tire to stop the line. With foam in the tires the tractors would keep going after the rubber was falling off. This was in 94 and I believe they were charging $1500 a wheel. Now they used a denser mix for tires than roofs. I'm not sure how they archived the desired denseness. I think it was changing up the part. Part b ratio. Anyway my point is it they can fill tires through one small stem hole I'm pretty sure a rops could be filled through several holes. It's just a matter of having the practice knowledge of he materials. Tiger foam sells a 2 part kit for like $500. It will cover 700 sq ft 1 inch deep. It's pricey but thear is another option, having a foam shop do it.
Spirit Electric Tricycle (A64127)
Spirit Electric...
2018 Deere 670GP (A64126)
2018 Deere 670GP...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
