leaf collection
/ leaf collection #21
Do you hand rake the leaves into a pile and then pick them up? Or does your fingered grass catcher rake in the leaves in piles to pick them up with your vacuum system?
/ leaf collection
Beenthere,
So far I haven't had a real opportunity to put it to the full test. But my plan is to disassemble the tubing and use the blower attachment to blow the leaves into either piles or windrows. I suppose that piles would be the better option at which point I would basically rake the leaves to the end of the suction unit. I might try to attach the original vac attachment to the tubing just to ease the process. The rake is wonderful for long piles of grass but not so much for leaves. By making piles of leaves in regularly arranged rows I could use a sort of hybrid pile/windrow technique by which I simply drive from one pile to the next and use a hand rake to move the leaves to the tube opening. Thus far, the small tests I have done show that the dry leaves get sucked up with no effort at all. We have some gumball trees that leave their annoying gumballs on the ground. But they also get sucked up with ease and get shredded nicely too. This was a good sign as I was a bit concerned as to just how dense/hard an object the vac could handle. It also shredded some small sticks, but I won't through too much of those in the vac. Essentially, I can drive tractor with the trailer to an optimal point and then hand rake to the opening and let the airflow work its magic.
Its been fun so far,
SI2305
/ leaf collection #23
Seems you have the blower attached to the sideboard of the trailer, why not connect the end of the tube near the outlet of the mower deck. Then mow over the leaves and suck in what blows out as you pull the trailer while mowing?
I was thinking you were looking for an easy way to pick up leaves. That to me doesn't involve walking around with a rake or a blower, or dragging a tube around. ;)
/ leaf collection
Beenthere,
I would have made an attachment to the belly mower, but as it stands right now, all I have is a rear discharge Land Pride RFM. While I could block off part of the outlet to concentrate clippings to my vac, this seems like asking for trouble. I think the plan will be to rake/blow leaves into piles then vac/shred them into the trailer.
SI2305
/ leaf collection
reason for the zebra,
OK, I think I should clarify my reason for my zebra, the 5$ truckloader. Typically, my neighbor lets me take every single leaf from his yard. Normally I would simply rake the leaves into great big windrows, piles, or piles in a line. The raking I find kinda fun and good exercise. The problem with this method has always been getting leaves into the trailer. While the raking is relatively fast and leaves immediate results, hauling those leaves into the trailer is a pain in the back (literally and figuratively). I have used rakes, big rakes, and even grain scoops. While I will eventually get the job done, hauling into the trailer has always been the slow part of the entire operation. further, the leaves tend to not pack well unless I use a grain scoop to push the load down hard into the trailer. Even then, I feel a bit silly as the trailer can carry far more weight than the packed in leaves would suggest.
This is where the truckloader comes in. As I have no belly mower or mower of any type with any sort of adjustable airflow, I mounted the vac and tubing backwards so that it could be driven forward with ease. I still plan to rake by hand, but I might have to switch to using the leaf blower in its conventional fashion in order to collect the leaves. Then I plan to mount it back to the trailer and convert it back to the truckloader configuration and suck up the piles instead of picking the leaves up manually/awkwardly with a large rake and Grain scoop combination. Hopefully then, the actual loading of leaves will be considerably eased and the leaves will come out shredded so I can load much, much more into the trailer (8'x4'x2'). Last but not least, I will then take these back to my gardens and give them a nice dose of chopped up leaves with which to add more organic matter into the soil.
I hope this clarifies the reason and justification for the general design of the vac truckloader.
SI2305
/ leaf collection #26
........I hope this clarifies the reason and justification for the general design of the vac truckloader.
SI2305
That explains the activity. I was not thinking that you just wanted to move raked leaves from the ground piles into the trailer.
Keep us posted how well it works out. We'll be anxious to hear about your venture.
/ leaf collection #28
Lay one of those big, light weight tarps out over your lawn. Blow the leaves onto the tarp and simply fold the tarp, with the leaves in it, haul it along to where you discharge your leaves and spill them out....or, put the tarp and leaves in your trailer and go.
/ leaf collection #29
SI2305
Sound like you know your fair amount about blueberries..
I have just recently started to plant a few and was wondering:
Are walnut leaves and hulls good for blueberries since they are so acidic?
And any other info is welcomed either here or PM me thank you
/ leaf collection #32
If I don't remove the leaves then I have no grass.
Some situations are different depending on the amount of leaves, the spacing of the trees, the species of trees, and the type of lawn one wants.
Can be quite different strokes for different folks. :D
/ leaf collection
RE: Blueberries,
I have two rows of blueberries for a total of nine bushes. They have been planted over a period of about 3 years. They are fussy little plants in their first couple of years before they become established. I have also lost some, probably due to excessive heat. From my experience of both success and failure I can confidently suggest the following:
1) Pine needles are probably the best mulch, but they will take years to change the Ph to any significant degree. That is based on my experience with the soil here in Southern Illinois, a section of the state that was never glaciated, hilly, and has a hard clay soil--much unlike that of the entire rest of the state.
2) You will need some other type of acidifier--Aluminum sulfate will do the job quickly but interfere with fertilization (I think it inhibits the uptake of phosphorus, but I am not completely certain of that one). Elemental sulfur--bright yellow stuff--will do the job but more slowly. It will actually slowly convert into sulfuric acid (I know--scary--but this is how the process works) where it will then dissolve iron for the blueberries which need that mineral in huge amounts. As far as I know, there is no way to just simply add iron directly to the plant and avoid the Ph issue, though one old trick was to push rusty nails into the ground as a supply of iron. I have considered the same with rebar.
2) Leaves, whether they be Oak, hickory or walnut, though acidic are no where near enough to alter the Ph of the soil, at least in the clay we have here. Walnuts are particularly tricky in that walnuts play a game of chemical warfare with most other plants. the leaves and roots (and likely all parts of the tree) contain chemicals toxic to most other plants. People who have walnut trees in their backyards frequently have difficulty in getting grass to grow, and when they do, the grass often dies out quickly. If I knew I had a patch of walnut leaves, I think I would just burn them and not let them near anything that I wanted to grow.
3) When you plant your blueberries, use a nice, loose soil, preferably one high in organic matter and sand. DON'T fertilize on the first year, just let those roots become established. After the first year, check the Ph again, amend the soil as necessary and fertilize, preferably with one of the more organic types (they tend to last longer) such as the epsoma acid soil fertilizers. Don't harvest this year. In fact, pick off the flowers as they appear so as to help strengthen the root zone.
4) WATER. These plants don't tolerate drought, so find some way to keep the soil nice and moist, even in the hottest of days. I use a drip system I purchased through Dripworks. The system is perfect for this type of planting. WATER, but don't soak. Blueberries don't like to be drowned out. This is where the Pine mulch comes in. My mulch row runs about 2 feet wide and probably 6-12" high except for the spot where the blueberry plant sticks up, At those points, I level out the mulch so that the blueberry leaves rise above the mulch layer, so at these points the depth of the mulch is determined by the plant itself. I personally let the pine mulch go right up to the base of the blueberry plant, and as the blueberries get taller, the mulch height becomes less of an issue.
5) Weed barrier. I always use a weed barrier in all my plantings. Weeds are hugely competitive plants and will rob your plantings of nutrients, water and eventually sunlight if they get too tall. They also tend to harbor disease and transmit it to your blueberries, yet be immune themselves. I generally lay down a layer of newspaper (2-3 sheets will be fine as long as it does not become punctured by a weed), but you can also use cardboard (very sturdy), computer paper, or almost any paper-type produce. I have been warned about using the shiny colored type of paper that is used in magazines, but I honestly don't know why this is so important. Nevertheless as I am a teacher, I receive bundles of useless papers (from the administration, not students) each year. Instead of recycling this I reuse it (higher form of use on that triangle, but it still upsets some people). My pine needles go both below and above that paper layer. Below thinly so as to provide a nice soft layer for the paper, above to keep the paper in place. Over time, all of this will break down, but it will have done its job and if necessary, just re-apply the barrier again. It makes a nice way to discard of paper waste and help the soil all at once.
6) consider some type of cage for the blueberry plant, especially in the early years. Birds and deer will get your crop before you do unless you do something to stop this. Trust mer here. I have watched a blueberry bush produce hundreds of berries and just before they get ripe for the picking, ALL of them will be gone! I blame deer the most, but birds get in there also.
I hope this helps anyone interested in planting blueberries,
SI2305
2005 Peterbilt 378 Day Cab w/ Wetline 834826 (A62613)
2005 Peterbilt 378...
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
John Deere 1023E (A62177)
John Deere 1023E...
John Deere 1025R Tractor (A64047)
John Deere 1025R...
2005 International 4400 Truck (A61573)
2005 International...
2012 PROCO 130BBL VAC TRAILER (A63569)
2012 PROCO 130BBL...
