GC Series Filters, OEM And Aftermarket Part Numbers
   / GC Series Filters, OEM And Aftermarket Part Numbers #1
ray66v
Super Member
Ohio
GC2310,
Now that there are more manufacturers making filters, please post your findings, so new owners can find them all in one thread.
Here are some part numbers I found using the TBN search feature, information is from posts made by members, and considered reliable, but not guaranteed.
Engine oil filter Baldwin B7356
Fuel filter Baldwin PF937
Engine oil filter WIX 51360
Fuel filter is WIX 33262
NAPA air filter 9691
NAPA Engine Oil Filter 1360
Engine Oil filter Fram PH4386
OEM Numbers Massey Ferguson GC 2300/ GC2310/ GC2400 / GC2410 / GC2600 / GC2610 Compact Tractors:
Engine Oil Filter 72201898
Transmission/Hydraulic Filter 4265229M1
Air Cleaner Element 3757472M91
Fuel Filter Element 3608255M1
   / GC Series Filters, OEM And Aftermarket Part Numbers #2
I have the same oil filter 72201898 for my 1423, do you mean i could use the fram ph 4386 for a replacement. if so, thanks for the info.:D
If it's the same filter, yes.
   / GC Series Filters, OEM And Aftermarket Part Numbers #4
Thanks ray66v, dealer charge me 12 dollar for a oil filter. I should be able to get a fram at western auto for at least 4 dollars.:thumbsup:
   / GC Series Filters, OEM And Aftermarket Part Numbers #5
That number may not be a Fram number. Luberfiner uses th PH prefix as well. I have had some luck with a cross reference at hydraulicstore.com. I would check there before I bought the Fram filter. Using the number rayV66 is showing, I am finding different filter numbers at hydraulicstore.
I checked the Fram site by using the Wix 51360 number as a cross reference. I found they show 2 part numbers, PH4967 and PH4746. The PH4746 is listed as an AGCO tractor filter.
There are subtle differences in these, and the member that used PH4386 found it to fit. The relief is set at 14 psi for all these, so no problem there.
It looks to me though, like Fram would recommend the PH4746 as a better number to replace the 72201898 MF filter.
   / GC Series Filters, OEM And Aftermarket Part Numbers #7
oil filter 72201898 will cross reference to Fram PH2951 for $4.50 at ORielly's
   / GC Series Filters, OEM And Aftermarket Part Numbers #8
My MF1529 also uses the 72201898 oil filter. Thanks for the info. I'm also interested in the hydraulic fluids, air filter, fuel filter and hydraulic filter.
   / GC Series Filters, OEM And Aftermarket Part Numbers #9
Advance planning: soon I will be ordering a GC1715. So I want to start buying oil and filters for the unit so it doesn't require trips to the dealer who is out of town range.
Any chance the numbers used for the gc2300/gc2400 are the same for the GC1715?
2017 Ford F-250 (A55973)
2017 Ford F-250...
MASSAGE CHAIR (A58214)
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2008 CAT 305C (A53317)
