370D Beaver Parts Cross Reference List
/ 370D Beaver Parts Cross Reference List #1
KenBer
Hi All,
I've spent the last few years researching reasonably priced and available replacements parts for my Satoh 370D (Beaver), so I figured I'd share it with everyone here.
Oils:
Engine Oil - 15w/40 Diesel Oil (.8 gal/3L)
Trans/Hydraulic - AW46 (2.6 gal/10L)
Axles - 80w/90 Gear Oil (.25 gal/1L)
Tires:
Front = 5-12
Rear = 8-16
Alternator/Water Pump Belt:
1/4"(6mm) x 35-1/4"(895mm)
NAPA - 25-7348
Air Filter:
Kubota - 70000-11221
FRAM - CAK530
NAPA - 6270
Hastings - AF167K
Wix - 46270
Oil Filter:
FRAM - 3593A
WIX - 51334
WIX - 51344
SUPERTECH - ST3593A
Fuel Filter:
__with bleeder screws
Baldwin - BF7845
GUR - GFI89060
__without bleeder screws
FRAM - G6459
NAPA - 3387
WIX - 33387
Purolator - F54498
Champ - G2932
Alternator:
for ~1972 Ford Courier 1.8L 4Cyl
BBB/Reny - #14194
Beck/Arnley - 1860103
Starter:
for 1978-1980 Dodge Colt 2.6L 4Cyl
/ 370D Beaver Parts Cross Reference List #2
Wow, useful post, thanks! This is awesome!
/ 370D Beaver Parts Cross Reference List #3
Just to add to the list,
Air filter car quest 88270
Baldwin PA1865-fn
Oil filter napa 1041 or 1042 gold
Balwin b1425 or b31
/ 370D Beaver Parts Cross Reference List #4
Hi All,
Starter:
I was looking at this list and noticed you didn't put down the part numbers for any of the various manufactures of the Starter. As I was looking at RockAuto, I noticed that there were two different parts, one for the manual transmission and one for the automatic transmission.
Do you or anyone know which is actually the match for the starter on the Beaver? I assume the housing is slightly different based upon the bell housing it is mating up with.
/ 370D Beaver Parts Cross Reference List #5
There's an old post somewhere on the forum on a replacement for the starter solenoid for the Beaver. It's a good match, but has to be slightly rotated to fit. The rotation still allows the wire from the starter to connect to this solenoid. The solenoid was listed for a 1985 Mitsubishi Mighty Max 2.3L engine. L-4. diesel.
Holy smokes, when I got mine from Rock Auto, it was a closeout and cost about $20.00. I just looked up the same solenoid on Rock Auto, and there were two listed, one for $120.79 and another for 89.79. Seems like a bad second choice now. I think I would now in a pinch, purchase one for another Mitsubishi from 1985 and compare it with the original.
/ 370D Beaver Parts Cross Reference List #6
The dodge he was talking about had the 2.6 L 4cyl which was a mitsu engine.
I would like to add an oil filter number: Hastings LF402
/ 370D Beaver Parts Cross Reference List #7
On the subject of oil filters, I needed a filter for my Subaru and one for my Beaver. Same filter. :D NAPA 1334, same as WIX 51334.
/ 370D Beaver Parts Cross Reference List #8
Your list shows the alternator from older ford courier as a good replacement. I'd ad that if you ever run into one of these in a junk yard (or the Mazda equivalent) cut out the majority of the under hood electrical plugs. Your tractor plugs are the same as these. I was able to replace the plug on my alternator and from the switches by just swapping out the pins.
/ 370D Beaver Parts Cross Reference List #9
I would like to know about the starter as well since mine is starting to take a dump on me. Anyone know exactly which one will work?
/ 370D Beaver Parts Cross Reference List #10
I don't know about a replacement starter but I have a Buck and a grey 3 cyl. Beaver. When I have starter trouble I take it to a local starter/alternator shop.
/ 370D Beaver Parts Cross Reference List #11
I will note on the alternator that electrically it is identical. However the mounting is slightly different, not a big deal but I did have to lengthen the tensioner bracket by about 1-1/2".
/ 370D Beaver Parts Cross Reference List #12
Anyone got a fuel cap p/n?
/ 370D Beaver Parts Cross Reference List #13
I own a Case IH 254, made by Mitsubishi. A good friend of mine has a Beaver with the 2cyl diesel. It's surprising how similar they are. Some times he sources parts through the Case dealer. Not cheap but at least they are available. Might try and see if the Case 235, 244, 254 Mitsubishi made tractor fuel caps are similar.
Chuck
/ 370D Beaver Parts Cross Reference List #14
Anybody know what light bulb the headlights use on an S370? Got one that is rather uh... bad. Didn't see any numbers on it to go by.
/ 370D Beaver Parts Cross Reference List #15
I got two head light bulbs at napa. They got out the manuals from a 70's motorcylce. Just take the old one with you. It's a split watt for high and low. Can't remember the numbers, sorry
/ 370D Beaver Parts Cross Reference List #16
Those numbers are what I want though. :( Of course I don't have it with me. Actually, the one I removed had come apart inside the housing. Have to pull the good one out for a visual comparison.
/ 370D Beaver Parts Cross Reference List #18
This is really great, thanks.
Anyone got any ideas on where to find a front axle for 4 wheel drive Beaver?
Ron
/ 370D Beaver Parts Cross Reference List #20
do you know about cross over parts for a S373D I am looking for a starter and alernator.
Ron
