Generator backfeeding into utility lines
/ Generator backfeeding into utility lines #41
People seem to always call a pole with wire on it a telephone pole. Why I don't know. The only time it's a telephone pole is when there is JUST telephone wire on it...all other times the electrical utility owns the pole and rents space to the communication utilities and it is properly called a power pole.
Per a retired phone company lineman... telephone poles where here first.
Don't know if what he said is true... but he is sticking to it...
/ Generator backfeeding into utility lines #42
I dropped the female end of a live extension cord into a sump pit filled with water just the other day, scared the heck out of me thinking something was gonna blow up, but nothing happened, just pulled it out, didn't even trip the breaker.
That's not surprising....ever seen anyone "load bank" a generator with saltwater? Sometimes the salt is added to water in a given ratio to achieve the desired conductivity and then the generator's output "probes" are inserted into the brine a little at a time to vary the load. Other folks just insert the probes completely into the water with the genny breaker on and then starting tossing in salt until the desired load is applied.
Watch this clip with a couple of portables:
Generator load test - YouTube
Google "salt water load bank" or "salt water dummy load". There's some pretty interesting stuff.
/ Generator backfeeding into utility lines #43
Interesting, I don't completely understand what's going on there, but the guy seems pretty confident he knows what he's doing.
JB.
/ Generator backfeeding into utility lines #44
The power lines are not copper any more. Much to expensive. Aluminum is used.
/ Generator backfeeding into utility lines #45
I've heard of it happening but I never personally saw it. WHY that is such a rare event is open to much conjecture...it might be that the Sask Power customers are too cheap to actually buy generators :D or the outages (which are rarely of any real duration) are just too short for most people with a generator to bother hooking it up if it isn't absolutely necessary to do so. I'd like to think that the people who do have generators are also intelligent enough to have a proper hook up that prevents any backfeeding situation.
Maybe Canadians are just smarter :D
Seriously, maybe a little closer to the basics ????
Or maybe just math, less of them so, even on a per capita basis, less idiots?
JB
/ Generator backfeeding into utility lines #46
So this poses a whole new question. With the number of people who now have some form of green power (solar, wind, etc.) that at any point in time can feed power back into the grid at any point in time I can't see how any lineman would ever work on a line without protecting themselves first.
/ Generator backfeeding into utility lines #47
The saltwater is basically a liquid rheostat that can be adjusted to obtain the desired resistance by changing the concentration of salt and/or varying the exposure area of the submerged probes attached to the generator.
More information here:
Liquid rheostat - Wikipedia, the free encyclopedia
Here's another clip, this one shows two Cat generators being load tested with a salt water tank. A bit more intimidating than the other video...this setup is @440 volts and 640 kilowatts. It gets interesting at 1:20 or so:
Generator Load Test. - YouTube
:thumbsup:
/ Generator backfeeding into utility lines #48
Per a retired phone company lineman... telephone poles where here first...
Actually, I think "Telegraph" poles where here first.
A better term is probably "Utility Pole"
/ Generator backfeeding into utility lines #49
hehe, this is the 4th or 5th post like this that Ive seen in the past month. Bottom line is its illegal to back-feed a house without the use of an interlock. Period. That being said they are available for under $20 at most wholesale houses for a basic butterfly interlock (for small subpanels) to about $100 for an intricate heavy duty unit (for main panels). Siemens now has a panel with a built in generator subpanel that can handle either a manual trasfer switch OR any brand of automatic transfer switch controls, and costs about $300 (wholesale)
Not to ague the legaities because I really don't know and nothing around my area has ever said anything to that end.
That being said, if it was illegal, I would think that the 2 firemen at the beginning of the right away wouldn't be backfeeding and they do.
When the utility company came to re-string the downed lines, they stopped at each of our houses and asked us to shut down our generators...No one was fined or arrested.
Again, I know full well that this dangerous if you don't know what you're doing and I can certainly see the risk from a novice user.
I believe that the utility company came out with a meter mounted transfer switch..One of these days I'm going to look into that.
I personally would prefer a whole house standby unit. Just not practical for me given the very limited number of outages that we experience.
/ Generator backfeeding into utility lines #50
Not sure about your neck of the woods, but here in pacific northwest...illegal. The utility companies will shut off and lock out the power if they find out you have it wired illegally until its fixed. They are always sending out notices asking people to fix illegal wiring, They will even inspect the installations for free and recommend mitigation issues. Its real easy to spot most perminant mount units
/ Generator backfeeding into utility lines #51
JB.
Basically, pure water is not conductive. It is the impurities, chemicals, salt, and so forth that make it conductive. Take for instance high power water cooled transmitter tubes. The tube's plate is submerged in water and it has many thousands of volts on it.
/ Generator backfeeding into utility lines #52
:thumbsup:
Yeah, all I could think about was a Frankenstein movie :)
Looks like a standard test procedure for those big gensets.
I just plug in some electric heaters to load test mine :eek:
JB
/ Generator backfeeding into utility lines #53
If you want to feed your whole panel you will need a service rated transfer switch, they are twice the cost of a standard double pole-double throw knife blade switch.
Could you educate me about the differences of these 2 switches please? I will be hooking up a new service in the near future and need to start researching what I need to buy. If both are rated for the same amperage is the one still twice the cost? I always thought a transfer switch was just a DPDT device.
/ Generator backfeeding into utility lines #54
I think that have a device that detects the connection to the utility. If the utility is not sending power they shutdown automatically. Solar systems cannot operate independently from the grid unless they have batteries and auto disconnect. This is my understanding. Please let me know if I am wrong.
/ Generator backfeeding into utility lines #55
The only warnings we ever get is to tell us not to run the generator inside the house.:confused:
Sounds like your utility companies provide an additional service, that doesn't exist here.
/ Generator backfeeding into utility lines #56
Ok, I'm getting an education here :)
Interesting. As far as shock hazard goes, then why is it worse to be standing on a damp concrete floor lets say barefoot as opposed to a dry concrete floor? There is a greater shock hazard with the wet floor isn't there???
JB
/ Generator backfeeding into utility lines #57
JB
When I say pure water I mean pure. Something that doesn't normally exist unless the water is processed and filtered like deionized, distilled, very clean and pure.
/ Generator backfeeding into utility lines #58
JB
You're now talking about the electrical resistance of your skin. Dry skin is something like 500x the resistance of wet skin. Would a dry salt have the same resistance as salt water? If I remember correctly dry salt is an insulator.
/ Generator backfeeding into utility lines #59
Their is a code that covers disconnecting from the grid applies to all forms of self generated power. By code you are required to have an automatic disconnect if the grid goes down. Solar panels will work just fine without power from the grid. All they require is sunlight. One of the advantages of solar panels is that if you loose grid power you still have electricity from your panels (during daylight hours and limited by the amount of power your panels can produce of course).
My point was that if a weekend warrior who thought he knew electricity decided to add a wind turbine or solar panel to go green and didn't know the code covering the potential of sending power back into the grid is there. Some power companies require you to sign a form saying you have the correct equipment and some inspect it. However a weekend warrior who thinks he's doing his part for the planet may never even think about any of this.
/ Generator backfeeding into utility lines #60
The code requires that any device used with the service equipment be "service rated". It has a higher ground fault capacity that the individual branch circuits. If you do know what all this means take my word for it as it is too technical for this forum. So if you are doing the switch selecting of either utility power and generator power at the main breaker level "whole house system" then that is the service entrance. I am trying to make a "licensed electrician" knowledge level something you can understand. It is all about your safety. If you have a sudden fault to ground things can virtually explode and cause a fire or worse if you are in front of it.
This dialog is very important to understand when dealing with heavy commercial/industrial applications or things such as large pumps and compressors.
A more recent issue is arc fault protection. You will encounter this if you do a new installation or major retrofit such as your panel replacement. All bedroom circuits now have to have arc fault circuit breakers. There is a lot to know in the electrical business. It is not for novices.
Of course you all by now should know about ground fault devices in circuits, either at the breaker or the outlet. That is discussion for a different forum as this one also should be.
Ron
Case-IH Puma 180 (A64911)
Case-IH Puma 180...
2020 KENWORTH T880 TRI-AXLE HYDROVAC TRK (A67714)
2020 KENWORTH T880...
2009 INTERNATIONAL SF647 GARBAGE TRUCK (A66091)
2009 INTERNATIONAL...
2014 FREIGHTLINER CASCADIA 113 S/A DAY CAB TRUCK TRACTOR (A69167)
2014 FREIGHTLINER...
2018 Dodge Charger Sedan (A66738)
2018 Dodge Charger...
2007 (INOPERABLE) INTERNATIONAL DURASTAR 4300 (A67714)
2007 (INOPERABLE)...
