At the corn !
/ At the corn ! #1
D7E
manitoba
Versatile 895 Versatile 876 Ford TW20 Ford TW5 MF 3505 FWA MF 390 FWA Ford 7600 Fiat 766 FWA JD 2030 MF 165 MF 35 Fordson major x 3 CAT 416 b Backhoe Case 580 b backhoe MF
Just a few pics of the corn harvest .
/ At the corn ! #2
Thanks for the photos.
Two questions.
1. How were your yields this year?
2. How far away was the bear?
Steve
/ At the corn !
Two questions.
Steve
Variety's varied from 140bus in the pioneer / 110bus in the dekalb down to 70bus in the syngenta. Yogi was a couple of hundred feet away but taken on the move and zoomed too much !
Knocking it into shape ..!
/ At the corn ! #5
Thanks for the pics! What latitude are you farming at? Sounds like very good yields to me.. given you're just "up the block" from Iowa!! :D
Fine lookin' dirt you've got there, too. Sure like to have at least another 4 inches up here like that to add to the 4 we've got.
Very shallow soil up here given the short window for organic breakdown and cycling.
Some corn in the greenhouses, though! :thumbsup:
AKfish
/ At the corn ! #6
Look at all that whiskey. :D :D
Wedge
/ At the corn ! #8
Nice picture of the Machinery all lined up and posed!:thumbsup::thumbsup:
Yah, sure enough!! I was trying to figure out which tractor goes first.... The Ford or the Versatile or (not sure exactly what the 1st machine is).
Disc 1st and then run the spring tooth chisel or...
Maybe D7E will fill in the blanks! :thumbsup:
AKfish
/ At the corn ! #9
Nice pics! The corn here was pitiful we had the drought of the century and temps over 100 for over a month straight and 55 days total no crops made it not even irrigated.
/ At the corn !
AKfish
Disks are usually avoided at all cost ..too heavy maintenance , too compacting on the soil, and leave land rough but for corn stalks are essential if a burn is not possible , so they go first to slice then the 2 chisel ploughs do all the rest (2 more passes) . The field they are parked in is wheat stubble so has just had 2 passes with the chisels .
The 40ft on the vers is a chisel same as the 31ft on the ford but a 9 in space shank as opposed to normal 12in so we can use it in spring as "drying " cultivator if neccessary .
Final pass on all land is with the super harrow to leave a nice seed bed but on stubble it does the very first pass also to spread straw and chaff , germinate weeds/seeds and pin straw down into the base of the stubble to allow better incorporation on following passes with cultivators.
/ At the corn !
/ At the corn ! #12
Thanks, checked out your other videos, too. Enjoyed 'em.
AKfish
/ At the corn !
Final pass ....!
JMR Tree Spade Mini Skid Steer Attachment (A61572)
JMR Tree Spade...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
2016 Cadillac CTS Sedan (A61574)
2016 Cadillac CTS...
Caterpillar D3 Tractor Service and Parts Manuals (A63117)
Caterpillar D3...
2025 Hydraulic Drum Mulcher Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
2017 Ford Transit 250 Cargo Van (A61573)
2017 Ford Transit...
