Welding Galvanized Material
/ Welding Galvanized Material #1
NCMau
Gold Member
NC
MF 202/Ford 8N
I have a fair amount of galvanized 1/4" angle iron stock that I have been using for years in different projects (arc welding). I guess I am following safe procedures by always welding outside with fans blowing.
My question is: how much of the coating you have grind off for an effective weld?
Also I noticed if I heat the metal with the torch for bending, the coating pops. Should I also grind the area before heating? I suppose that would minimize splashing.
/ Welding Galvanized Material #2
heating doesn't matter but should grind all coating off before welding and u should think of buying a respirator that smoke from galvanizing is really bad for ya
/ Welding Galvanized Material #3
If you get zinc poisoning (from the galvanized burning off...you'll have some difficultly breathing, IIRC), drink milk. That will alleviate it. You may want to go to the hospital...depends on how you feel.
However, grinding it off first is your best best (use a respirator for the dust). Grind about 2" or so from the weld joint. I doubt you'l be able to tell with your welding helmet on, but zinc burns with a green flame.
Thanks. Respirator is a great additional precaution. I have one that I use for paint. Can I use the same one or should I get a different one.
/ Welding Galvanized Material #5
Read the fine print, mine uses the same filter for both. I think you can weld right over the galv., just avoid the fumes. I'm not an authority on anything welding related tho.
/ Welding Galvanized Material #6
You can weld or (in my experience) braze without grinding the galvanized coating....that's why I know the zinc burns green.
However, then you will get the fumes.
/ Welding Galvanized Material #7
You can weld over the galvanised but it will be ugly, smokey and spattery. If you can't grind first, maybe use stick instead. Silicon Bronze is a faily good wire to use on galvanized or a gasless wire like NR211. The gases from the galvanized causes problems with the argon mix.
/ Welding Galvanized Material #8
Grinding the zinc produces both particulate and gasses. Hard to get a nice weld without grinding off the zinc. Easy to get a great braze, though. The zinc seems to make a great flux for bronze.
I don't like packing the respirator under my helmet, but it's worth it.
/ Welding Galvanized Material #9
Right on, zinc & brazing rod love each other.
Welding with stick or ? makes for a poor quality weld, usually week & pitted.
Fumes are poison, if you get enough that you can taste the zinc, drink lots & lots of milk. Work outside and wear a good mask.
/ Welding Galvanized Material #10
I usually blow off with a torch then wire wheel, or grind off.. whatever I got handy..
that and weld outside with it / fan.. just try not to breathe welding fumes.. any of them.. zinc or not.. :)
soundguy
/ Welding Galvanized Material #12
I've welded literal tons of galvanized material. Multi-million dollar marine structures. Been poisoned at least a dozen times! Nothing fun about it, one miserable night, but OK the next day. Other than the lack of sleep!
Best thing I've found to weld galvanized material with is Hobart's Fabshield 21-B wire. Grind off the excess galvanizing, and have at it.
/ Welding Galvanized Material #13
/ Welding Galvanized Material #14
Back in my younger pipefitter days we welded galvanized pipe a lot. Never ground off the zinc and never had a weld problem except the fumes. The zinc didn't into the root pass and burned off as you built up. We even gas welded smaller pipe. In fact the welded area maintains a lot of the galvanizing cororrison resistance. Fumes!! I breathed that suff so much that after 35 yrs I am still allergic to the stuff. Earlier, I got to the point I had to refuse to weld it even with respirator and sucker. Now that I am older, and I hope smarter, the medical aspects indicate do not do it, bolt it up or if you need the corrosion resistance make it up of bare steel first and send it out for galvanizing after fab. Once you cut or grind the zinc coating the rust will start any way unless you touch up the zinc coating. That spray can stuff only last as long as it takes to put it on. The hot process (that is how it goes on originally) is just as dangerous and requires a heating torch and a little know how. With the painting systems and powder coating available today galvanizing is probably on the way out. Enviornmental and OSHA rules have shut down a lot of the galvanizing shops and it has become a very expensive system.
/ Welding Galvanized Material #15
When i have to weld galv pipe, i wear my hobby air respirator unit. It draws fresh air from 50 feet away and the other side of my shop and pipes it thry a 3/4" hose to my 1/2 face mask. I also use it when plasma cuttiong and painting. There not too expensive and my lungs thank me. I modified mine with a 10 foot intake hose that is perminantly mounted outside my shop and has a hepa filter installed.
available online, ebay, etc http://www.clmcenterprises.com/
/ Welding Galvanized Material #16
got a link to post for that kit?
/ Welding Galvanized Material #18
bingo!
soundguy
Welded zinc and made green smoke. Never been sick. I might have turned blue though. I rolled with the punches, ducked the smoke.
If I've got a bunch of galv to grind or weld, I put on the mask.
/ Welding Galvanized Material #19
/ Welding Galvanized Material #20
thanks for the link!
not a bad price for the half mask OR the hood.
I may pick one up for my shop.
I am planning to convert one of my garage bays into a paint bay, vs painting outside all the time.. if i do that.. I'll want supplied air..
looks like just the ticket..
soundguy
They are a nice unit. I got mine on ebay for even less $$ than some stores sell them for. I especially like the clean fresh air while painting....cant stand to breath spray fumes.
2007 CHEVOLET MALIBU CAR (A66091)
2007 CHEVOLET...
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
2014 KOMATSU D65PX-17 CRAWLER DOZER (A65056)
2014 KOMATSU...
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
2013 Ford F-150 Ext. Cab Pickup Truck (A66736)
2013 Ford F-150...
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
