YW-6 Backhoe Problem
   / YW-6 Backhoe Problem #11
Hi Guys,
Actually leaking piston seals (on a single ended, double acting cylinder) wont cause a cylinder to drift. The volume of oil contained in the cylinder increases as the cylinder extends and decreases as the cylinder retracts. This is caused by the area in the cylinder occupied by the piston rod. If your control valve (or some other source outside the cylinder) is not leaking, there is no way for the volume of oil in the cylinder to change and essentially locking the cylinder in one position. So for your boom to be drifting down, there has to be something outside of the cylinder (usually the control valve) allowing the volume of oil in the cylinder to change. Thus causing the cylinder to change position.
This does not apply to a double ended cylinder where the volume of oil contained in the cylinder is the same no matter what state of extension/retraction the cylinder is at.
:)Ditech--
I believe you left out one important consideration, and that is there are external forces, working to apply pressure to the cyl, therefore acting as a manual pump, pushing fluid to the other side of the piston. The weight of the boom and bucket are trying to extend the cyl by weight alone.
I also believe that most people in this situation, are changing out the piston seals, less expense for one thing, and correcting the problems than they are replacing their control valves.
They both can be checked using a manual hyd pump.
   / YW-6 Backhoe Problem #12
Hi Guys,
The information I posted earlier was purely from memory (we can all probably relate to that :confused:) anyway, the basis for my opinion is still true. Check out the link below Troubleshooting hydraulic cylinder drift
It's interesting reading and may shed some light on what I was trying to relay. I know I don't post a lot, but I do get a lot of good insight, opinions and advice that I can apply to my tractor. Hopefully, occasionally I can add something of value to the forum. I appreciate all of the "regular" contributors and respect their views. When I offer an opinion that is against the grain I will try and back it up with reliable data, info or from a looooong time in the heavy diesel trucking industry
:) Ditech
Thanks for all the information. There is one thing I should have added. When the backhoe was first installed, it had a problem. When the fluid would heat up, the hoe lost all of its ability to do work. The boom would barely lift, etc. So I increased the viscosity of the hydraulic fluid and that solved the problem. The boom didn't sag and there were no other apparent problems. Then about a year or so later the boom began to sag.
There is one behavior/symptom which I'm not sure is normal or not. When the bucket is in contact with the ground digging and I apply downward boom force, there is a one or two second delay between giving the control command and the boom actually applying the downward force.
I push the down control lever the boom will move down and makes contact with the earth, wait one, two.. then the boom pushes down and the rear of the tractor lifts slightly. I'm not sure if this is normal or not.
   / YW-6 Backhoe Problem #14
No , not normal unless there is some loose pins , etc, Sounds like air in the cyl. Air will take time to compress up to the hyd pressure necessary to move the cyl, whereas the hyd fluid will start to move things instantly.
   / YW-6 Backhoe Problem #15
Hi Guys,
:) Ditech
I enjoyed that well done presentation on debunking the myth of creeping hydraulic cylinders (cool software). Maybe I missed it but I didn't observe his mention of of a couple of tons of static force being applied to the cylinder while it was in "locked" state, which is the back hoe scenario. I'll view it two more times.
   / YW-6 Backhoe Problem #16
What were you using for hydraulic oil in the beginning?
What did you do to "increase the viscosity?
Yes.
It may be that the return oil from the cylinder is slightly restricted, and that must be overcome before the cylinder will move (how is the return line filter?), or as JJ said, there could be air in the system.
12345
I changed the hydraulic fluid from ISO 32 to ISO 68. When I switched from 32 to 68 the filter was clear with no debris. I haven't checked the filter since.
By the way, I've often wondered, what's the major difference between hydraulic oil and engine oil. Obviously the engine oil has more additives, but can it be used in place of hydraulic fluid? Hydraulic oils can be hard to find and aren't that much less expensive than engine oil when bought by the bucket.
   / YW-6 Backhoe Problem #18
Are you in the tropics or down by the equator? Does the oil say "ISO AW 68 Hydraulic Oil or something else?
A lot!
Actually hydraulic oil has more additives than you think. Most are blended from paraffinic base stocks and will have additive packages that include anti-foaming and ant-wear agents, and moisture dispersants not found in engine oils. And conversely, engine oils contain additives that are undesirable in hydraulic service. People make entire careers from lubrication so I'm not going to go into any depth on the subject. But just common sense will tell you: engine oil for engines and hydraulic oil for hydraulics.
Yes, in special applications where it is indicated. Otherwise no, not by knowledgeable people.
It is as close as the nearest auto parts store, NAPA dealer, or petroleum distributor.
12345
Actually the bucket said AW68 not ISO, yes it said hydraulic fluid. No I don't live near the equator. I started with AW 32 and the backhoe had no power, barely enough to lift the boom up into the upright position. Several other owners stated they had solved the same problem by going to a more heavy weight fluid. AW68 fixed that problem.
HOWEVER, today the original problem is now back. Last time I used the backhoe it worked fine but after a while the boom would lower on it's own. Now none of the backhoe hydraulics have enough power to do anything including lifting the rear of the tractor with the outriggers.
I checked the fluid level and it's normal. I unscrewed the filler cap and the cap was covered in water. It was dripping.
Awhile back I bought a spare unused hydraulic pump at a good price so I'm going to swap it out to see if that improves things. Before I do that I'm also going to drain the fluid and check the in tank strainer.
When I move the control lever the outrigger will suddenly move normally for a fraction of a second then move very slowly with no power. Almost like there is an obstruction.
   / YW-6 Backhoe Problem #20
Well now it sounds like you have debris in your relief valve, notwithstanding a possible blown pump. Is the new pump rated about 7 gpm? It's entirely possible that you have multiple issues, one masking the other.
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
2019 VOLVO A45G FS OFF ROAD DUMP TRUCK (A60429)
2019 VOLVO A45G FS...
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
2022 Ford Explorer AWD SUV (A59231)
2022 Ford Explorer...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
