ROPS AND U-BOLTS...Hmph
/ ROPS AND U-BOLTS...Hmph #1
DwightD123
St Louis Mo
LS R4041EZ
Ok so I get the basic concept of how you would attach a strut (light bar) using U-Bolts but here is the problem: The Strut is slightly smaller than the interior of the ROPS so as to not cause any structural change by pushing out on it. When I use the U-Bolts they still have enough sway to move up and down making for a sloppy mounting plate. Do I need to do some alteration to the U-Bolt or get one that is a bit too small and squeeze it on there. Right now I have about 1/2 inch free room on each U-Bolt. I sure wish I could just weld a bracket and forget about it...but sure as I do there will be an issue down the road and I will be S>O>L.
Can anyone give me some close up pictures of how they have used U-Bolts on the ROPS? Thanks!:
/ ROPS AND U-BOLTS...Hmph #2
Cut a groove in a hockey puck and insert to take up the slack.
/ ROPS AND U-BOLTS...Hmph #3
Bend the U bolt with a torch and vise to fit. If I understand what you are trying to do, you will have plenty of spring back left to get it in place.
The other thing I think you might be talking about is a "Z-direction" gap. If so, then just space it with rubber strips, washer, steel plates....whatever.
/ ROPS AND U-BOLTS...Hmph #7
ditto that. I usually torch and bend allthread to make custom ubolts when i mount stuff.
soundguy
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
2021 Jeep Gladiator 4x4 Crew Cab Pickup Truck (A66736)
2021 Jeep...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2025 24in Bucket Mini Excavator Attachment (A66734)
2025 24in Bucket...
7 foot bucket (A64194)
Welcome to the Ranch Metal Decorative Sign (A64557)
Welcome to the...
