ROPS AND U-BOLTS...Hmph
/ ROPS AND U-BOLTS...Hmph #1
DwightD123
St Louis Mo
LS R4041EZ
Ok so I get the basic concept of how you would attach a strut (light bar) using U-Bolts but here is the problem: The Strut is slightly smaller than the interior of the ROPS so as to not cause any structural change by pushing out on it. When I use the U-Bolts they still have enough sway to move up and down making for a sloppy mounting plate. Do I need to do some alteration to the U-Bolt or get one that is a bit too small and squeeze it on there. Right now I have about 1/2 inch free room on each U-Bolt. I sure wish I could just weld a bracket and forget about it...but sure as I do there will be an issue down the road and I will be S>O>L.
Can anyone give me some close up pictures of how they have used U-Bolts on the ROPS? Thanks!:
/ ROPS AND U-BOLTS...Hmph #2
Cut a groove in a hockey puck and insert to take up the slack.
/ ROPS AND U-BOLTS...Hmph #3
Bend the U bolt with a torch and vise to fit. If I understand what you are trying to do, you will have plenty of spring back left to get it in place.
The other thing I think you might be talking about is a "Z-direction" gap. If so, then just space it with rubber strips, washer, steel plates....whatever.
/ ROPS AND U-BOLTS...Hmph #7
ditto that. I usually torch and bend allthread to make custom ubolts when i mount stuff.
soundguy
300 GAL WATER TANK (A68842)
300 GAL WATER TANK...
Generator Inverter (A64553)
Generator Inverter...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2016 Ford F-550 Ext. Cab 4x4 Stake Body Flatbed Truck (A66736)
2016 Ford F-550...
2002 Sterling M8500 Acterra Landscape Dump Truck (A66736)
2002 Sterling...
2018 Mitsubishi Eclipse SUV (A66738)
2018 Mitsubishi...
