Cover cropping
/ Cover cropping #1
ayelvington
Gold Member
Russell, PA
BX24
I'm taking some worn out field and working to convert it to something that will support a healthy food plot. We're plagued with clay covered with about 4" of top soil.
I have cover cropped it with buckwheat for two years and plowed the mulch under. This fall I planted winter wheat to plow under in the spring. I'm working on improving the tilth of the soil and weed suppression. (I got the goldenrod running!)
Here's my question: How many of you cover crop your food plots, and why?
/ Cover cropping #2
My go-to foodplot (for putting venison in the freezer during the daylight hours of gun-season) is corn, but I do use several other plots for "cover". When I am starting a new plot on old pasture land, I plow it in the late spring and disc it every other week or so throughout the summer. I also work in lime if needed (pay for a soil test) that first summer. Around Sept 1, I disc, then broadcast about 1 bu/acre of rye grain, then cultipack. Then I broadcast about 2 lb/acre of white clover and cultipack again, 90 degrees from the previous direction. In addition to building the soil as a cover, the deer use the rye heavily the first fall and following spring. Tonight I watched (6) of them feeding in my rye from the house while we were eating dinner. The rye does a great job keeping weeds at bay, and helps the white clover get a good jump in the spring. I usually mow the rye when it is about a foot high in the spring, and mow the clover a couple more times to keep the weeds under control. The second fall, you should have a real good stand of white clover which I also consider a cover crop, this time to control weeds and build nitrogen that will be utilized by corn in another 2-3 years. At that time, the clover gets plowed under shallow in the spring and corn gets planted, requiring very little fertilizer for modest yield thanks to all the nitrogen that has been stored up by the previous 2-5 years of white clover. Cover crops are a great way to save megabucks on fertilizer and herbicides, with the added bonus being the fact that, if you pick the right ones, the deer like to eat them. Anyone who tries to do foodplots without utilizing cover crops is really missing the boat in my opinion.
/ Cover cropping #3
I plant wheat here as a cover crop every year. It's like a deer magnet when other plants die off. The seed is cheap at 16.00/ acre (2 bu, common soft white wheat).I plow some down,if the weather lets me next spring. Some, I let the deer eat all the heads they want when it matures, and then cut and bale about half for the straw. The other half, they come in and eat the left over heads in late August- September till their gone. I also frost seed clover, so that is in the wheat stubble for this time of the year. We also have several acres of alfalfa, trefoil, vetch, fall oats, corn, and soybeans. Want something planted that area farmers don't have to draw them in any time of the year, and that covers it, believe me, it works. Makes a nice food source and mellows the ground.
/ Cover cropping #4
What are you calling a “cover crop”. A cover crop is a plant that is planted with another crop to provide some “cover” so that other crop can get established. Hope that made sense. Wheat is often planted as a cover crop over clover in the fall. Come spring/summer, the wheat is either mowed or harvested.
I get the impression that you mean something different when you say cover crop?
/ Cover cropping #5
Al, Afternoon... I had a worn out pasture and planted Piper Sudan grass one summer... I have irrigation also... The sudan takes a lot of nitrogen to grow but in return can put as much as 10 tons of grass back into the soil in one season/acre... I ended up mowing it every 2 weeks with the brush hog.. it was 18-20" tall in that time with 16-16-16 spread on it every 4 weeks.. Great organic matter to restore the soil.. in the fall I disked it in... In the spring planted alfalfa... Sudan Grass...
/ Cover cropping #6
The farmers here in NY started planting some type of radish, for a cover crop this fall. It has a deep tap root with not much top growth. Lossens the ground better than grasses. Top rots very quickly. In the spring, they disc it over a few times and ready to plant. Does anyone know the name, and how it works?
/ Cover cropping
What are you calling a 田over crop? A cover crop is a plant that is planted with another crop to provide some 田over so that other crop can get established. Hope that made sense. Wheat is often planted as a cover crop over clover in the fall. Come spring/summer, the wheat is either mowed or harvested.
Actually, you and I are on the same page. My "food plot" needs its soil enriched, so I've planted buckwheat to break up the clay, and winter wheat as a weed suppressant and green manure in the spring.
I'm still enjoying the direction that the thread has taken though!
/ Cover cropping #8
Try this link.
Radish cover crop
/ Cover cropping #9
Thanks for the link. Looks like this could be the new cover crop of the future.
/ Cover cropping #10
Forage Radish is the name. It aerates the soil with its long root and its a great scavenger of nutrients and holds it for the next crop to use. It winter kills thus making it easy to establish the next crop.
The University of Oklahoma did a study where they Fall planted about 5 lbs of Forage Radish with 2.5 bushels of Wheat to the acre behind corn and got a 20% increase in the yield of the Wheat when harvested.
/ Cover cropping #11
Also called tillage radish. I’ve not tried them myself, nor have I ever seen them planted in this area. I do plan to plant a couple fall annual food plots next spring with them so they aren’t just sitting empty waiting for fall plantings. I hope to take advantage of the soil improvements, as well as using them to graze cattle in mid summer.
/ Cover cropping #12
Where I live and on most site what you mentioned is called a nurse crop to protect the young seedlings. Cover crops are crops that are planted after harvesting or before the main crop to provide green manure and also weed suppression.
/ Cover cropping #13
Also called tillage radish. I致e not tried them myself, nor have I ever seen them planted in this area. I do plan to plant a couple fall annual food plots next spring with them so they aren稚 just sitting empty waiting for fall plantings. I hope to take advantage of the soil improvements, as well as using them to graze cattle in mid summer.
Look for groundhog forage radishes as they have an incredibly long taproot. I've planted brassicas for a few years and usually plant them in late july or early august for good growth. I made the mistake in the past to plant them too late and too thick as they will take over a food plot. Also they love nitrogen. Deer love them after they sweeten up after a good frost.
MMagis I see your from Ohio, you might want to contact ernst seed for their brassicas they are located in western pa. and have an online catalog. I've ordered from them in the past with quick service for everything from clover to brassicas to switchgrass.
/ Cover cropping #14
Ditto.
And there may be a problem with what you are doing. Plowing under, especially doing it twice in one year. There is a very good chance that you are losing more organic matter than you are putting back.
The radishes would help you. Just leave them in the ground.
/ Cover cropping
I plant as a cover crop for the reasons that you mentioned.
/ Cover cropping #16
Those long rooted radishes are Japanese daikon - we lived in Japan many years, and love them! The Japanese make pickles out of them, grind them up to put in sauce for tempura, cut them up and boil like regular turnip roots, etc. They are great!! If you like turnips, that is, which we do. I didn't know they could be used to help the soil; I'll have to try that too.
/ Cover cropping #17
I've had good luck planting crimson clover as a cover crop on some of my plots. The photo attached is from April. Decided to test one plot by bush-hogging it in June after it seeded and letting it reseed. It grew and looks great now going into the winter.
2007 Top Brand Deck Over Trailer, 18'+3' Dovetail (A62679)
2007 Top Brand...
ATTENTION PLEASE READ (A64127)
ATTENTION PLEASE...
1998 Volvo VNL64T Sleeper Truck (A62679)
1998 Volvo VNL64T...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
1997 Titan Gooseneck Trailer (A66285)
1997 Titan...
2025 TEXAS PRIDE 14FT T/A DUMP TRAILER (A59914)
2025 TEXAS PRIDE...
