Pull behind snowblower
/ Pull behind snowblower #21
flyingcow said:
I've yet to go out and clear the drive until the storm is over, with the exception if someone needs to get out or in. For me it works best to wait until its all over with. 4 inches or 3 feet. Thats why i love my 16x16 trans. Incredible creeper gears. Still would like to try a pull type.
That is the same reason we bought a power shuttle, lots of choices.
You would not be disappointed with a pull type.
/ Pull behind snowblower #22
Now that i think about it, I probably wouldn't be disappointed. the occasional big azzed storm, once you break a path it would be a breeze.
/ Pull behind snowblower #23
Yupp, I agree. Dad broke many a path with our Ol' 35, never had an issue getting through either. And, no sore neck. :)
/ Pull behind snowblower #24
In my opinion the biggest disadvantage is that by driving over the snow you are packing down what you hope to remove. This doesn't work well for snow or when leveling soil. I've seen the videos on Youtube but the pull behind wouldn't work for me.
/ Pull behind snowblower #25
Bigturk:
I don't have a pull-behind (yet), but our snow in NH typically isn't too heavy, and doesn't create a problem w/ a rear 7/ blade. Maybe you get the ocean-sprayed snow?
/ Pull behind snowblower #26
What happens if you have snow too deep for the tractor to drive through? All the snow-blowing power in the world isn't going to make a difference if you can't drive forward to feed snow into the blower.
The MF35 has a lot of ground clearance and large tires. I assume ag tires.
I don't think he'll have that problem, like one might have with a small compact tractor.
/ Pull behind snowblower #27
Bigturk:
Hi daveinnh,
Yes, our snow in Nova scotia is usually very wet. We get the snow that you don't want to keep in NH, only a day or so later.
/ Pull behind snowblower #28
In defense of Lucknow (Helm Welding) blowers, in 7 years of blowing snow (and ocassional planks and cinder blocks along with some gravel), the only maintenance I've performed on the blower was a gear oil change last year, just because I thought it to be prudent and greasing the outer auger supports and oiling the chain drive for the auger. That's it other than greasing the universals on the PTO driveline. Nothing has broken, nothing has worn out and the blue paint is still intact, much to my chagrin......:)
I did add a set of skid shoes when I first bought it, ala Meyers round floating shoes.
I had a Landpride prior to the Lucknow and it wasn't even close to being as well built.
It sits all summer, next the barn in it's blue splendor, awaiting the snow that always comes.....:laughing:
/ Pull behind snowblower #30
Have you had that much snow in one storm?? We have, but still got it blown. If the weather gets bad, it gets blown during
Ing the storm. Don't wait until the storm is over. Plus, driveway was open, no trees, or any kind of shelter, no snow fence.
If it is that deep, you are going to have problems with a reverse blower too.
Rarely do we get a big dump at one time; but Xmas '82 and T'givin' '83 were huge storms that shut the Denver metro area down. We've had a few others that caused serious problems; but nothing like '82 and '83.
Anyway, I don't tolerate cold well and so I tend to wait till the storm is over and things warm up a bit and the wind isn't blowing.
/ Pull behind snowblower #31
I went back and forth a bit on this but finally decided that this was the time to try out a pull forward type blower.
We haven't had enough snow in a storm for as long as I can remember now that I could not drive through so long as I blew the snow at some point during 24 hours.
I have a 75" Meteor on order along with my new M7040. I imagine the bigger tractor with ags will also help driving through anything that falls here.
/ Pull behind snowblower #33
5030, I have adjustable skid shoes with my current blower and I actually took them off after a summer or two. I found that the blower just didn't go close enough to the ground even with the skids at min height.
What I do is that in the case of the first few snowfalls I just drive over the snow and pack it down so I have a good layer of snow over the gravel.
An interesting option on these pull forward blowers is a blade that hangs off the back. I never got it as it was 600 bucks but I can see how it can provide a nice clean look.
/ Pull behind snowblower #34
I could see a pull type blower working for a lot of snow falls. However, where I live, it is the winds and drifts that cause the issues. 6" snows with 3-4' drifts that stretch for 25-50+ yards are not uncommon. 6' drifts not that rare. No rear pull blower on a tractor is going to make it through. Once you get high centered or if slick, you are done.
2 years ago I had drifts that were over 6' in my driveway and on the road. No place to push it. Rear snowblower just chewed its way through them at a very slow pace. On my Toolcat the snow was over the cab. I could not open the doors on either side more than a couple of inches. Weird sensation of looking at walls of snow on either side. I was worried about getting stuck and not being able to get out of the cab. I don't use the blower much, but in really deep snow, there is no other tool than can do it but a conventional blower.
/ Pull behind snowblower #35
ya, i hear you. I take care of some neighbors driveways that have drifting issues. Can easily get 4 feet deep.
I was actually looking into getting a pull behind blower (way cheaper than what i ended up getting) but how in the heck could i clear the horse barn when it sheds????
/ Pull behind snowblower #36
I bought one for $20 and used it for many years. As long as the snow wasn't too wet or deep, it worked well. It had 2 pipes welded on the right side, so you could slide on an extension wing for widening. The extension wasn't with it so I just welded some smaller pipes to half of a 55 gal barrel and it worked ok. If you tried to hog too much though, It would suck the tractor into the bank and plug the blower in a hurry.
/ Pull behind snowblower #37
I started out with no shoes. because I live in Monroe County where the road comission never comes out and plows until after all the body shops are full, we never see any snow removal for at least 3 days and sometimes never. Consequently, my reason for the Lucknow was to do the road from the farm to the paved road, about 1 mile. It's all dirt. With no shoes, the lower edges of the side sheets on the Lucknow were wearing away. I hard rodded the lower edges but they still wore so the solution was skid shoes.
I don't mind leaving a 1/2" of snow on the road, That's a whole bunch better than 2 or 3 foot drifts....and it keeps the blower from acting like a full auto machine, I mean gravel gun.....
I'm actually perusing for an old snowblade that I can weld to a Bobcat style hitch plate and put on the ATI quick attach on the fel.
With that, I can make a pass with the blower and the return with the blade.
It takes 2 passes to open the road and I love winter, I always make some good pocket change pulling people out of ditches, drifts and other places they should stay out of, but don't and it's usually a jacked up 4wd pickup with mudder tires that gets stuck. I carry my snatch strap and keep a big clevis on the drawbar. You get to the end of the snatch strap and whatever is at the other end, always comes out..... one way or another.:D
I typically charge 50 bucks cash for a pull and a hundred if they instruct.:thumbsup:
It might sound steep but consider being on a lonely country road, in the ditch or buried in a drift and it's way below freezing and you don't want to call Central Dispatch for assistance because if the Sherriff comes out, you can't pass a breathalyzer test.....
/ Pull behind snowblower #38
You are way too domestic.:)
I blow a path to the horse barns so I can get to the round bale feeders and water tanks.... That's it
Of course I don't care for horses anyway. They belong to the wife. Horses are like boats, a hole that you pour money into.
Gimme cattle or hogs or something that you can butcher or sell at market weight.
When the nags are gone (under ground), I'll plant alfalfa, tear down the horse barns and actually make some money instead of blowing it on hayburners.
/ Pull behind snowblower #39
Now dont hold back, tell me how you really feel about horses :laughing:
/ Pull behind snowblower #40
Actuaslly, I don't mind them. They are all Percheron Draft Horses and very gentle. My wife would bring them in the house if she could, I guess. I know they'd wind up in the basement as the floors would give way.......:laughing:
I'm allergic to horse hair.
2025 SDLANCH SDL2030GT Heavy-Duty Greenhouse Tent (A64194)
2025 SDLANCH...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F-250...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
1995 Ford LT9000 Tri-Axle Dump Truck (A64556)
1995 Ford LT9000...
INTERNATIONAL 5300 END WHEEL GRAIN DRILL (A64278)
INTERNATIONAL 5300...
2008 Case CX240B Hydraulic Excavator (A64194)
2008 Case CX240B...
