Steering linkage ~ missing boot?
/ Steering linkage ~ missing boot? #1
Coyote machine
Super Member
Southern VT
22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
Driver's side steering rack. Starting at wheel working toward center of tractor. Tie rod end with rubber boot enclosing it. Then another boot over a ball joint? (machine not in front of me so hard to recall exact layout); then a chrome plated shaft about an inch in diameter going toward and into rack. Is THIS shaft supposed to be covered by some sort of boot, or is it bare and open to the elements?
I ask because mine is bare and I don't remember ever seeing a bare shaft in this area before. I may well have torn off the boot, assuming there is one, when last playing in my muddy VT stream, turned raging river by the recent storms and my inability to stay out of trouble's way. Any help appreciated. :thumbsup::)
/ Steering linkage ~ missing boot? #2
On both my Kubota's, the shaft (hard chrome part) is exposed. I'd imagine that Kioti is similar.
Thanks for that! I'm hoping you're right.
BTW, What's a Kubota? :D
/ Steering linkage ~ missing boot? #4
5030,
It's what Kioti copied and got sued for in the 'Trade Dress Infringement' Lawsuit a few years back that was settled out of court.
In all honesty, I'm not brand loyal so long as it's not green is good with me....:D
Don't u know imitation is the sincerest form of flattery? And since Kioti wasn't copying so much as improving on what Kubota was doing it was to everyone's benefit in the long run. :) No matter what color it's just paint in the end result. :thumbsup:
/ Steering linkage ~ missing boot? #6
A picture would be really helpful, this may seem silly, but you are not talking about the hydraulic power steering cylinder are you?
Joel
/ Steering linkage ~ missing boot? #7
Joel
It's not hydraulic power steering anyway. Its hydrostatic power steering.
5030: Hydrostatic steering using UTF, hydraulic fluid, no?
Joel: Yes, I guess I am referring to the piston which drives the wheels left or right; you say it is the power steering cylinder. So is it booted or bare metal?
Thx, CM
/ Steering linkage ~ missing boot? #9
If you can see the chrome rod when standing in front machine looking down at it, the brush guard is missing. Brush guard bolts to the tie rod and extends over the cylinder barrel to help protect the chrome rod.
Yes, the shaft is covered by the shield and can be seen when looking from beside the left front wheel area. Otherwise it is less visible.
I wanted to verify that it is supposed to be exposed, and does not require a boot.
Thx.
CM
/ Steering linkage ~ missing boot? #11
CM,
See if these pics help you....just took them on my DK40SE HST. This is of the left/driver's side.....(the 3rd pic is looking from the bottom up....sorry, it wasn't at the best angle).:laughing:
As you can see, mine is bare except for the protective shield on the top side.:thumbsup:
/ Steering linkage ~ missing boot? #12
Thx, CM
Hydraulic assist steering consists of a hydraulic cylinder and modulator assembly and possibly a second slave cylinder. Hydrostatic steering is a self contained unit housed in the steering box assembly. Kubota and Kioti share the same design. The hard chrome rods you see are the articulating ends of the hydrostatic cylinder. nothing fancy, been doing that for years. The half round covers protect the rods from damage from objects that could knick the rod itself and cause a fluid leak.
Fluid is fluid. So long as it meets or exceeds the manufacturers specification, it's all good. I quit using Kubota UDT and SUDT years ago. I run Chevron full synthetic and my steering gear oil comes from the sump that supplies everything else except the engine oil
I'm not a picture taker but my Kubota's have the power unit for the steering mounted atop the engine and the rack unit is fed with hard lines from there.
/ Steering linkage ~ missing boot? #13
Yes the hydraulic rod is Visible no worries
On my tractor the steering is hydraulic powered off the hydraulic pump
Hydraulic versus hydrostatic is splitting hairs both work with pressurized oil
Sounds like in this case it is hydraulic and you are just seeing the cylinder rod which is totally normal
Long story short I think you are fine
Joel
Challenger 35/45/55 Parts and Operation Manuals (A63117)
Challenger...
Kubota M4700 (A60462)
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
Adams 5 T Fertilizer Spreader (A63688)
Adams 5 T...
(2) Lights (A64119)
(2) Lights (A64119)
2018 Dodge 5500 Bucket Truck 4WD (A63689)
2018 Dodge 5500...
