Farmtrac 535 Disaster
/ Farmtrac 535 Disaster #1
redlevel
Gold Member
100 miles south of Atlanta
Kubota MX 4800
My 535 went Tango Uniform yesterday. Water in the oil, slapping/knocking/expensive noises in the block. Made the last payment in August. I guess I took a chance and lost. Not quite 700 hours. Changed oil, filters regularly. I used it pretty hard on the farm, subsoiling, harrowing, bottom plow, etc, but I have used small/medium utility farm tractors hard all my life (Ford, MF) and I have only had one other one (out of at least 25-30) go down like this.
Wishing now I had "bit the bullet" and bought a Kubota or New Holland. A utility ag tractor should go 5000 hours without anything other than regular maintenance and a small issue or two.
Live and learn, die and forget it all.:(
/ Farmtrac 535 Disaster #2
Most unfortunate - I am truly sorry to hear of your experience.
/ Farmtrac 535 Disaster #3
yeah, 30-35 hp compact utility tractors can't be expected to standup to work better suited for a heavier ag tractor.
I've used my 50 hp '00 FT60 with 1900 hrs to build two small ponds about four foot deep (down to bed rock) with a box blade and rippers and the FEL.
I realize my utlity tractor wasn't made for such work but most of the time its dragging a 7' rotary mower keeping my 40 acres mowed.
The 535 isn't a compact utility tractor. It is an ag utility tractor. It should have lasted a few thousand more hours before a failure of this sort. I have done the same tasks with a 600 Ford gasoline tractor. In fact, the implements I am using with this tractor were purchased in the 1950s by my fil for use with a 600 Ford. This isn't a case of using a tractor for a job it wasn't intended to do. Single shank subsoiler, two-bottom plow, five foot harrow, five foot mower, two row planters, etc. There is no excuse for this kind of failure at 700 hours.
/ Farmtrac 535 Disaster #5
I hate to read of a tractor with so little use, and not abused to go out like that farmtrac.I know my tractor has 730 hours or more and i would be devistated to find out it had died. Maybe you can do a search for an replacement engine, and restore it?
/ Farmtrac 535 Disaster #6
That really sucks...but I guess it's what one can expect from a chinese tractor.
Not Chinese, Roy. Made at the Escorts plant in India.
Maybe it isn't as bad as it could have been. Damage appears to be limited to top end, one cylinder. Swallowed a valve. Hopefully, no damage on the bottom of the engine. Also, hopefully, only minor damage to the head.
/ Farmtrac 535 Disaster #8
Wish you the best of luck, Bro!
/ Farmtrac 535 Disaster #9
Hope you have a chance to buy a better replacement valve.. Sounds like they might be of soft metal.. you might invest in a whole set and be ahead of the game.
/ Farmtrac 535 Disaster #10
Our Farmtrac was made in Korea but the engine is a Mitsubishi.
If your failure is confined to the engine, what engine is in yours?
Engine is a three cylinder diesel manufactured by Escorts in India. This isn't one of the compact utility tractors with the Farmtrac badge. Those were indeed made in Korea. The ag utility line was manufactured at the plant in India. They are the tractors that look like the 70s era Fords. In fact, on their old webpage, Framtrac used to advertise bolt-in crate engines for Fords of that era. The 535 is the smallest tractor in that ag utility line. It doesn't have a Ford clone engine like the larger ag utilities, but has an Escorts engine. My dealer I bought the tractor from, who is still just barely in business, said he has no trouble getting the parts.
/ Farmtrac 535 Disaster #12
Bad luck. I've seen those Indian tractors in Asia with many thousands of hours still going strong even with minimal maintenance. Sounds like you had bad luck with a valve casting. Hope the repair works out.
/ Farmtrac 535 Disaster #13
all tractor brands drop valves just some more than others.
Got the repaired tractor back to the farm Monday, a day or two shy of a month after it went down. The dealer ordered the parts and everything came in except valves/seats, which delayed things by about three weeks. Replaced one complete piston/rings/sleeve assembly, valves, head gasket, magnafluxed and milled the head. Total charge, including oil, filter, anti-freeze, etc, machine shop, was $1175. All things considered, fairly reasonable, I guess. 90 day warranty on all parts and labor. Tractor is running good now, and glad to have it back. Meanwhile, I bought a JD 5105 with 400 hours, so I am "tractor poor" now.
/ Farmtrac 535 Disaster #16
Friend of mine has a 535 and his problem is the bearings in the front axle (4 wheel drive) went out. Dealer fixed it under warranty. 20 hours later,(about 6 months later) tractor warranty over, The bearings crapped out again. We ended up getting his Massey 35 running and he has been using that. We are trying to get all the parts so we can fix the 535 again. Wish we had a good IPC for the tractor. :(
He ended up selling all his cattle so does not need the 535 now. We will fix it and sell it. Hopefully, be done with it this summer. :thumbdown:
/ Farmtrac 535 Disaster #17
Here you go
http://lib.store.yahoo.net/lib/yhst-97092812362812/PARTS435.PDF
Operators and Service Manuals for Farmtrac and Mahindra Tractors and Implements
I know some guys do not like this guy due to the whole FarmTrac debacle, but he has never done me wrong and gotten parts that had to be sourced from the factory in India for reasonable.
Just an update . . . I sold my 535 a week ago. I ran it on Craigslist at what I considered a top-dollar price. Within two hours, I had sold the tractor. It had given me good service since the repair, but I could foresee having problems with parts acquisition in the future. It took my dealer nearly a month to get the parts and repair the tractor. I believe the parts were on backorder nearly three weeks. Evidently, the tractors are holding their resale value better than I thought they would. I guess the time of year, and the popularity of that size tractor/loader combo for small gardeners and food-plotters had something to do with it. Makes me feel like I should have asked more, but I am satisfied with what I got.
I got more than enough out of it to buy a loader for my JD 5105, have it installed, buy and install a fiberglass canopy for the JD, and to have some work done on my 600 Ford.
/ Farmtrac 535 Disaster #19
I would love to hear a full review and see some pics of that 5105 when you get a chance. My friend has one and it will leave my 56hp John Deere 5203 mfwd in the dust in a race! We've tried several times and he beats me off the line everytime and leaves my by about 8 lengths. Not that you should be racing tractors but we have haha
2012 VANTAGE TRAILER PMEUMATIC CEMENT TRANSPORT TRAILER (A63569)
2012 VANTAGE...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
2011 Nissan Juke AWD SUV (A61574)
2011 Nissan Juke...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2009 Ford F550 Flatbed w/ Lift Gate (A62613)
2009 Ford F550...
